Should this spot of rust stop me from buying this bike?
Bikes: ca.1975 Gitane Interclub - 90's Colnago Master Competition- ca.'84 Merckx Corsa - '77 Groene Leeuw - ca. '78 Guerciotti - ca.1984 L'Express - 1974 Gitane 'Super Olympic' - Peugeot 1981 PXN10 - 1975 Peugeot PR10 -1974 Norta -1974 Peugeot PX10 LE
Looks like rust where the fork meets the headtube ... Should it worry me?
Quoted: 128 Post(s)
Liked 12 Times
Can't see it very well, at all, in this picture. Look closer. If the rust appears to be surface rust (which is by far the most likely) then you're fine. You should worry more if the paint appears cracked from bending or impact, anything which might indicate that the head tube is separating from the fork blades. But a bit of rust around the joint, by itself, isn't an indicator of danger.
"c" is not a unit that measures tire width
If it's just under the headtube race, I agree with Stacey, it's oil from the grease that's seeped out and collected dust. I can't see any other signs of rust in the picture, but I always have trouble with trick questions.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
On the other hand, those brakes would make me think twice...
Today, I believe my jurisdiction ends here...
Quoted: 380 Post(s)
Liked 106 Times
Those are really good brakes because the cables are almost direct not angle pulled. Pauls is currently making basically a newer version of this brake. Some improvements but much more $$$$$. The brakes would be one reason I would consider that a good bike. Roger
Quoted: 443 Post(s)
Liked 27 Times
Aren't those MAFAC cantilevers? They don't look like much, but I've always heard good things about them.
What kind of bike is that?
The 531 stickers on the fork speak to quality. I can't tell if that is even rust from picture, either. If you are really concerned drop the fork out and take a closer look.
Quoted: 273 Post(s)
Liked 10 Times
Quoted: 273 Post(s)
Liked 10 Times
Quoted: 140 Post(s)
Liked 163 Times
I'm curious about what kind of bike that is. Cool looking fork, and you can see the Reynolds stickers on it as barba said. From what I can see of the bike, it looks interesting. No way to tell a thing about the rust, dirty grease, or whatever that is from that particular photo-
Quoted: 140 Post(s)
Liked 163 Times
Originally Posted by barba
The bike is a Gazelle, but I am not sure which one.
The Guadfather
Bikes: Trek, Centurion, Kuwahara coming soon
A Gazelle, I knew it!!
Paging Cuda2k....Cuda2k, there is a Gazelle spotted in the mechanics forum!!
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
"Minor bun engine, made Benny Lava!!!"
Quoted: 443 Post(s)
Liked 27 Times
Originally Posted by rmfnla
Thay are MAFACs and IMHO the only thing worse are MAFAC road calipers.
Unique Vintage Steel
The bike is indeed a Gazelle. This one being a Cyclocross version of the Champion Mondial, and a few years newer than mine as well. I believe the OP posted photos of this beauty in the Classic & Vintage a short while back. Great looking bike.
Back on topic, I agree that it appears to be grease, my Gazelle collects grease at that point as well, rather promptly too. Get some papertowel strips and get in there and wipe it down as best you can and see whats under the grease. If there's a little rust then it may be a good idea to pull the fork, and treat the rusted areas to prevent further oxidation.
New Orleans
Quoted: 157 Post(s)
Have owner probe with knife/screwdriver
If the owner doesn't want you to take it apart to get a better look,ask him to gently probe it with a knife of tiny screwdriver. If it is rust vs grease vs a little rust +lotta grease, it will be obvious.
If biggish ,deep rust scabs flake up/off them- JUST OFFER A LOT LESS!! It is still a decent enough frame otherwise-right?
Dirt drop is right. The absolute worst cantilever-v-brake or whatever brake from the last 15/20 years is much much better than the best 1970s state of the art Campagnolo R NR SR brake with stock pads-(the CampagnoloR NR SR brakes became almost not too bad with Scott Mathauser pads(expensive little suckers $10 in 1970's-like $35 now).All 1970's and earlier stock brakes were terrible by comparison to the cheapest dept store V-brakes. Rim surfaces have improved also, but I think it is mainly the actual brake designs, pad size, pad material that make the difference.The cables and casing probably stretch/compress less also.
Use the rust/grunge as a bargaining chip.
Luck
Charlie
Luck
Charlie
Quoted: 273 Post(s)
Liked 10 Times
You must not have much experience with crappy brakes. You could do much worse than MAFACS.
It might just be my personal prejudices; of course, seeing what bikes you list it might be yours.
Quoted: 443 Post(s)
Liked 27 Times
Trust me; I've have more than my share.
I've got MAFAC Competitions on the Raleigh, but only because it requires long-reach centerpulls and the MAFACS suck a little less than Weinmanns, IMHO.
