tektro brakes
tektro brakes
Hello, I need brake calipers for a bike I'm setting up. LBS has Tektro quartz 740, which cost 50% of Ultegra, and looks ok, light, koolstop pads etc.
do you know about any weakness about these brakes?
https://www.tektro.com/02products/08r750.php
thanks!!
thanks!!
Death fork? Naaaah!!
Tektro is the OEM for Cane Creek, Nashbar, and several others. I would not hesitate to use any of their products. In fact, my dirt road Miyata runs Tektro 925 mini V-brakes and 2.0 interupter levers.
Top
Top
I have two sets of tektro brakes. Nashbar calipers and Textro ultra long reach calipers.
The nashbar ones are cheapies (you can see where they cut corners) but work beautifully. The Tektro branded ones costa prettu penny but are very nice and work very well too.
I found that an old set of Shimano RSX brakes I bought has nicer machining and a better finish, but they don't work any better than the Tektros and are in a couple of spots slightly flimsier.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Top
Top
Today, I believe my jurisdiction ends here...
I replaced my stock Trek no-name brakes with long reach Tektro brakes about a year ago and have been very pleased with their performance. Great stopping performance and look good too I very high recommendation.
2007 Specialized Roubaix SL (building)
2004 Trek 1800c
2004 Trek 1800c
Quoted: 2026 Post(s)
Liked 1,096 Times
Originally Posted by Steev
A lot of people find the stock pads aren't too great and replace them.
2004 Trek 1800c
2004 Trek 1800c
Originally Posted by HillRider
Any chance you replaced Tektro brakes with Tektro brakes? I wonder who makes Trek's "no-name" brakes.
He drop me
Bikes: '03 Marin Mill Valley, '02 Eddy Merckx Corsa 0.1, '12 Giant Defy Advance, '20 Giant Revolt 1, '20 Giant Defy Advanced Pro 1, some random 6KU fixie
Quoted: 138 Post(s)
Liked 12 Times
Tektro makes Shimano's brakes too as well as Cannondale's and just about every other bike mfg that self brands brakes on their mid to low level bikes.
The higher end Tektros are actually very nice brakes and as posted they come stock with koolstop pads.
The views expressed by this poster do not reflect the views of BikeForums.net.
Quoted: 128 Post(s)
Liked 12 Times
"c" is not a unit that measures tire width
I have several bikes with Tektro and never have had a problem. The stock pads on the low end need replaced with Koolstops. The RX-40 is lighter than Ultegra and does the job just as well.
OP the 740 model. Is this the carbon model? If your getting them for less than Ultegra it is a deal.
Liked 1,096 Times
Originally Posted by oilman_15106
I have several bikes with Tektro and never have had a problem. The stock pads on the low end need replaced with Koolstops. OP the 740 model. Is this the carbon model? If your getting them for less than Ultegra it is a deal.
One "trick" I've used is to replace the front pads with Kool-Stops but keep the Tektro pads for the rear brakes. Sort of a poor-man's approach to the Campy "Differential Brakes", i.e., lots of stoping power in front and less in back so you don't lock the rear wheel as easily.
Quoted: 128 Post(s)
Liked 12 Times
I've used Nashbar's brake pad/pad holders to replace Shimano brake shoes on older model 105 and Ultegra brakes since the pad holders accept both Shimano and Kool-stop replacement pads. These are obviously Tektros and way less expensive than either Shimano or Kool-Stop pad holders.
