Burley Bossa Nova
Burley Bossa Nova
Old 01-05-07 | 07:15 AM
Burley Bossa Nova
Anyone know what brand of bottom bracket is on this bike? It is a 1994 and I want to remove the bottom bracket ot get it painted and want to get the right tools.
newbietotwo is offline
Reply
Old 01-05-07 | 09:51 AM
TandemGeek's Avatar
hors category
20 Anniversary
Burley's own proprietary bottom bracket. They are pressed-in sealed units. Best to leave it alone.
TandemGeek is offline
Reply
Old 01-05-07 | 10:29 AM
Bikes: Colnago C40 HP, Aegis Trident, Cannondale tandem
If yer removing if for paint and it's a 1994, you're also buying a replacement**********
ElRey is offline
Reply
Old 01-05-07 | 11:24 AM
So I understand this correctly, they don't come out?
Reply
Old 01-05-07 | 06:07 PM
zonatandem's Avatar
20 Anniversary
The older BBs from Burley are. as Mark said, 'proprietary'.
Once removed it may be difficult to re-insert it into the shell. A trick, that sometimes works, is to put the BB into your freezer overnight so it willl be easier to re-insert into shell.
Or just tape it over for the re-paint.
zonatandem is offline
Reply
Old 01-06-07 | 09:30 AM
Powder coating it so they need to come out. I got the eccentric out no problem, but the stoker bearings are being tough.
Reply
Old 01-06-07 | 04:24 PM
TandemGeek's Avatar
hors category
20 Anniversary
No, they come out and go back in just fine. However, it takes a pair of snap-ring pliers and a bearing press + the knowledge to use the bearing press. Any auto, motorcycle, machine or better bicycle shop should have a press and be able to do it for you.
Reply
Old 01-07-07 | 05:23 PM
Well went to a shop and had marginal success. Distroyed the bearings and spacer, got the spindle ( the important part). Will get new bearings and make a spacer unless there is another option. Anybody got an idea the assembly order for these pieces? I was thinking of pressing in the bearings with the spacer between and then driving the spindle through the whole mess.
Reply
Old 01-07-07 | 06:06 PM
WATERFORD22
Bikes: Bilenky, Co-Motion, 1969 Paramount, Waterford Adventure Cycle, Waterford rs 22, 1980 Davidson etc.
My friend recently had the whole thing replaced at a machine shop with new bearings and I think it was pretty reasonable also in the last 6 month new ones have gone on sale at ebay, but I had know reason to pick one up. Also if desperate a good bike frame shop may be able to covert. Let me know if you need to know what was need at a machine shop and I'll put you two in touch - where are you at Mike
vosyer is offline
Reply
Old 01-07-07 | 09:04 PM
The bearings are 6203-2RS I believe and they are cheap on ebay as well as other bearing stores. The only item I will have to make is the spacer. What I need to know is assembly order, what to attach when. I am in SW Ohio and have access to tools at a machine shop.
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
