trying to decide betwee kona Dr Dew and Trek 7.5 disk
Stewie
Bikes: Specialized Tricross and Gary Fisher Paragon 29er
I would like to thank those who in the past couple post who gave their comment on my search for new bike.
This whole process is new for me and a bit confusing. Especialy knowing the difference between components on differnt bikes
Can anyone give their opinion on the Dre Dew and the Trek FX regarding comfort and riding on gravel roads to doing some 100 km touring trips.
Would I be able to put 38's on the Trek, it has 32 slicks
How do the gearing compare between the 2 bikes?
I want road type gearing.
The Dr Dew is about $1100.00 Canadian and the Trek Fx is about $950.00
I am going form a mountian bike to the bybred type bike and can't get uset to those drop down bars at this time.
I was going to get the Dew Deluxe but ralized the Dr Dew had the bigger road crank set, 52/42/30
I find on my mountian bike that I spin out with my s speed gearing.
The Trek 7.5 FX dic looked good. It has holes on the front fork to put a front rack which the Dew does not have. The chain ring is Shimano M443 Octalink 48/36/26.
Being able to put on a front rack would be nice.
How does the Dr Dew 52/42/30 chain rings and the Trek 48/36/26 compare?
The Dew is Shimano DEORE (11-32, 9speed
The Trek is SRAM PG950 11-26, 9 speed
How do these compare?
Hopefully the liks below would be of some heip
https://www.konaworld.com/bikes/2k7/DRDEW/index.html
https://www2.trekbikes.com/bikes/bike...d=1342000&f=26
thanks again
thanks again
Out fishing with Annie on his lap, a cigar in one hand and a ginger ale in the other, watching the sunset.
Bikes: Techna Wheelchair and a Sun EZ 3 Recumbent Trike
Quoted: 9 Post(s)
Liked 22 Times
thanks again
thanks again
. “He who fights with monsters might take care lest he thereby become a monster. And if you gaze for long into an abyss, the abyss gazes also into you.”- Fredrick Nietzsche
"We can judge the heart of a man by his treatment of animals." - Immanuel Kant
Its only pain
Bikes: '18 Salsa Marrakesh, '14 Salsa Colossal, '89 GT Timberline
Quoted: 54 Post(s)
Double check the fork, I believe the Project 2 fork will have the threads for mounting a front rack. I have a Kona with the same fork and it has 'em. Nice fork, BTW, and the bike as a whole looks fantastic.
Stewie
Can anyone give an opinion on what bike would be the best choice between the Dr Dew and the Trek FX 7.5?
George Krpan
Quoted: 12 Post(s)
Why go to 700c? For dirt roads, fat road tires on 26" wheels would be vastly superior in speed, ride quality, handling, braking, and reliability. I think that 700c do cover the pavement A LITTLE more efficiently but you'd have to be a seasoned veteran to notice it. And, if you were a seasoned veteran you would appreciate the advantages of 26" wheels for touring.
Why not consider a REI Novarra Safari, $849? It is a touring specific design, not a mountain bike with slicks. It aleady comes with road tires and a really good looking rear rack. It also has cable actuated disk brakes and the fork has the full compliment of braze ons for a front rack. I imagine it could handle up to 26 x 2.4 tires or as skinny as tires get.
The gearing on the Safari is a 48/36/26 crank and an 11-32 9 speed cassette. It is geared lower than the Dr. Dew because the wheels are smaller. Still, a 48-11 combination on a 26" wheel is a big gear. You would not easily spin out. The gearing of the Trek is way, hopelessly, too big. Your mountain bike probably has a 44/32/22 crank and a 12/34 cassette. A 44-12 combination is much lower than a 48-11 combination.
Neither the Trek or the Kona are touring bikes. They have short chainstays which can cause your heels to rub the rear panniers. You might be able to solve it with a longer rack. But the big thing not in their favor is the wheels. They are both 700c wheels with 32 spokes. Touring bikes with 700c wheels need at least 36 spokes. Touring bikes with 26" wheels can use 32 spokes but the Safari goes the extra mile with 26" wheels with 36 spokes. You could always replace the wheels on the Trek and Kona with handbuilt 36 spoke wheels.
If you just gotta' have 700c wheels, in your price range is the REI Novarra Randonnee. It's got drop bars but you never have to use the drops. It can easily be equipped with auxiliary cyclocross levers so that you can brake from the tops or the hoods. It's got 36 spoke wheels and a 48/36/26 crank with an 11-32 9 speed cassette. It's exactly the same crank and cassette as the Safari but it is geared higher because the wheels are bigger. For this reason it could stand a change of cranks to 44/32/22. A 44-11 combination on 700c wheels is a big gear.
And, you could always change the Randonee to flat bars. The conversion is much cheaper than converting from flat to drop bars. However, you would have to find brake levers that are compatible with cantilver brakes or switch to v-brakes, easy and cheap to do. Neither the Kona or Trek could be switched to drop bars without swapping out their entire brake system. There is no such thing as road levers for the hydraulic brakes found on the Kona. The Trek has cable actuated disks but the are not campatible with road levers. However, Avid does make cable actuated disk brakes that are compatible with road levers.
Disk brakes are nice but they are not a necessity. Cantilevers are plenty strong. In fact, many people deride disc brakes.
