Brake Levers and older brakes
Livin' the Dream
Bikes: Bianchi Castro Valley 06, Specialized Allez 05
I have some older Shimano side pull caliper brakes (Shimano 640s I think) from an old 70s/80s vintage 10-speed that I want to reuse. However, I want to get some new brake levers. What brake levers can I use? Would any of these work? If not, can you please suggest some that would work. Thanks.
https://www.universalcycles.com/shopp...&category=2231
BTW - it is going to be a SS/FG bike so I might go with drop levers or flat bar levers.
The first two will work fine with drop bars. I you go with flat bars, you will need to find some flat bar specific levers that are labelled as cantilever compatible. The last levers you linked will work if you go with bullhorns.
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
The first 2 sets would work with drop bars. The first set is narrow. The second has a fatter grip. Both work fine. I like the fat ones.
The third set works in addition to a set like the other two. They mount on the flat section near the stem to provide a second brake lever position wile riding on the tops. The cable runs from the main brake levers and through these. Sometimes they are called interrupter levers.
Livin' the Dream
Quoted: 140 Post(s)
Liked 162 Times
Originally Posted by Drexman
Thanks. So if I go with flat bar levers, I need some that are "cantilever" compatible? Don't they need to be "caliper" compatible? Does it make a difference if they are old brakes, but new levers? The LBS told me that you need to make sure the levers pull the correct amount of cable.
Here's a link to my favorites for an older bike needing new levers: https://cgi.ebay.com/Cane-Creek-SCR-5...QQcmdZViewItem I think they're made by Tektro, very similar to the ones you linked to.
You Know!? For Kids!
I have the tektro r200a levers on my falcon. I like them. The quick release opening feature is nice for wheel removal. The best price I found was here.
https://www.triathlete.com/store/product.php?id=22336
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Livin' the Dream
Thanks for the input. Does your falcon have older caliper brakes?
You can read about my Falcon in this thread
Those cane creek are the exact same lever as the tektros. I found some on Amazon (actually niagra cycle works) for $9.99! Super-duper deal. Just search on Amazon for tektro R200. The R100's are the short reach version and they have them for $12.99. Still a great deal. I had some R200's on my bike for a while and they're really nice levers. The grip is slightly too bulky for my taste, but not terrible or anything. For $10 it's the best lever you can buy.
fun facts: Psychopaths have trouble understanding abstract concepts.
"Incompetent individuals, compared with their more competent peers, will dramatically overestimate their ability and performance relative to objective criteria."
Livin' the Dream
non aero vs aero cable routing I believe. I think the A denotes aero (cables exit side of lever to go under bar wrap) style.
R200a is the proper model name but most people just refer to the them as R200, there's no difference, same thing just leaving off the "a".
Livin' the Dream
Sorry to belabor this one, but now I'm thinking I might go with bullhorns. Would these work with older, single-pivot, caliper brakes?
https://www.performancebike.com/shop/...-_-null-_-null
