A crank other than sugino 75s that will fit a 75 bb and give you 42mm chainline
Old 01-23-07 | 08:20 PM
sore taint's Avatar
huge member
wondering if there is a budget crank that will give you a 42mm chainline that will fit the 109 mm sugino75 bb?
sore taint is offline
Reply
Old 01-23-07 | 08:36 PM
baxtefer's Avatar
Cornucopia of Awesomeness
pretty much any shimano square tapered road crank with the chainring on the inside
will be close enough to 42mm
baxtefer is offline
Reply
Old 01-23-07 | 08:40 PM
jacobpriest's Avatar
shadybikes
If i have a 75 BB, is that the same taper as Superbe Pro or am i ****ing up my ****?
jacobpriest is offline
Reply
Old 01-23-07 | 08:58 PM
exfreewheeler's Avatar
Stinky McStinkface
Bikes: Clemente Custom(not built-up), TI Raleigh Record SS, VitaSprint Mixte SS, IRO S.E.(coming) Ibex Trophy Pro
I believe it is... it's a standard JIS square tapered
exfreewheeler is offline
Reply
Old 01-24-07 | 10:14 AM
fatbat's Avatar
spinspinspinspin
Or a road crank with a 103mm bottom bracket and the chainring on the outside.
fatbat is offline
Reply
Old 01-24-07 | 10:38 AM
baxtefer's Avatar
provided that the crankarm clears the chainstay
baxtefer is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
