How Many Hours to Build a Frame?
Tiocfáidh ár Lá
Just curious experienced frame builders. How many hours does it take for you to build a frame? Let's say a steel road frame for example, lugs or no lugs from the time you select the tubes to the time the paint is done drying.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
According to a discussion from the framebuilders list, an experienced builder with a full bevy of dedicated machinery can get the metal work down to as little as 8 hours for a custom TIG’ed frame. More traditional building methods, such as using lugs and brazed dropouts, push the time to about double that. Add some detail work and the time becomes…? Figure on about 2+ hours for a basic paint job.
Quoted: 77 Post(s)
Liked 19 Times
Depends on experience of the builder. Depends on the complexity of the design.
Had a custom tandem built with mixed diameter tubing and handmade lugs. The lugs alone took 40 hours.
