index vs friction shifters/deraillers
fishologist
Bikes: Diamondback MTB; Leader 736R
So I am shopping for MTB parts for my rebuild, if the item doesn't specifically say, how do I know if I am getting a friction derailler or a index? I currently have a shimano xt front derailler and am looking for shifters and rear derailler. is the xt a friction or index? sorry if this is confusing
We cannot solve problems with the same level of consciousness that created them. A.E.
1990 Diamond Back MTB
2007 Leader 736R
www.cohocyclist.blogspot.com
https://www.loopd.com/members/cohocyclist/Default.aspx
2007 Leader 736R
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
Sheldon "Easy One" Brown
Code:
+-----------------------------------------------------------+ | Oh freddled gruntbuggly | | thy micturations are to me | | As plurdled gabbleblotchits on a lurgid bee. | | Groop I implore thee, my foonting turlingdromes. | | And hooptiously drangle me with crinkly bind-lewurdles, | | Or I will rend thee in the gobberwarts with my | | blurglecruncheon, see if I don't! | | -- Prostetnic Vogon Jeltz | +-----------------------------------------------------------+
High Octane
Bikes: Calfee, Spectrum, Colnago MxL, 3RENSHO, Softride Classic, TVT, Sentinel Whisper, Centurion Comp TA, Vitus 979, 92 RB-1, 94 RB-T, RADAC, 50th Anniversary Schwinn Paramount
Quoted: 5 Post(s)
Hi Mr. Brown,
Is there a way to get a Dura Ace ax rear der into friction?
I tried to use a DA ax rear der for a 7 or 8 speed indexed shifters but the ax rear der looks like its indexed for 6sp. I even tried disassembling the derailleur thinking I can grind those teeth from the der but now I can not even put the darn thing back to working condition. This is the part where the loaded spring goes back into the dropout bolt.
thank you in advance for any tips...
sincerely,
-gas
sincerely,
-gas
Meet Jack Ibagbaga (aka batillog)
https://batillog.blogspot.com/2007/05/wannabe-bob.html
Originally Posted by superunleaded
Hi Mr. Brown,
sincerely,
-gas
sincerely,
-gas
Shimano has published an alternate cable routing that allows an older DA shifter to be used with a non-DA derailer. Unfortunately, there is no solution for running things the other way around, other than getting a compatible (i.e. older DA) shifter.
Quoted: 24 Post(s)
Liked 6 Times
Hi Mr. Brown,
If you have a Dura-Ace AX derailer that's in decent condition, sell it on eBay, it is a museum piece, and belongs on a restoration project, not a "rider." Even a new $20 Tourney will work WAY better.
Sheldon "Derailers Are Cheap" Brown
Code:
+--------------------------------------------------+ | The less you bet, the more you lose if you win | | --Alan Rudolph (_Trixie_) | +--------------------------------------------------+
High Octane
Quoted: 5 Post(s)
The original plan was to build the bike with full AX components but after testing the shifting with the rear der, I found out that the rear der has this serrated part that makes shifting SIS like. It has postive stops for 6 speed shifting which I find annoying that's why I wanted to go friction.
High Octane
Quoted: 5 Post(s)
Thanks...
I'll just throw the AX parts in a bin and wait for the next project that is suited for that kind of components. In the meantime, I decided to go to a full DA 7410 build.
Here is the project: https://www.bikefanclub.com/gallery/s...500&ppuser=121
-gas
-gas
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
That's like throwing away money.
If you don't want the eBay hassle, please offer them on the Vintage forum. Someone would love to have them, I'm sure.
(Or did you mean bin as in storage, not as in trash? Maybe my vocabulary has become infected with Limey disease...)
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
High Octane
Quoted: 5 Post(s)
Sorry...
"I'll just throw the AX parts in a bin and wait for the next project that is suited for that kind of components."
When it comes to bike parts, nothing gets thrown away. They just wait... and wait, and wait for the next appropriate build. Appropriate for me anyway.
I got too many parts in boxes and bins that I have collected over the years. That and bikes hanging on the rafters
High Octane
Quoted: 5 Post(s)
Sorry cohophysh, I didn't intend to crash your thread.
I'll just go back to the c&v.
https://www.bikeforums.net/classic-vintage/259478-current-inventory-how-fill-up-your-garage-bikes.html
Quoted: 128 Post(s)
Liked 12 Times
Just so the general principles get out there:
Rear deraillers are not indexed. Rather, they have cable-pull ratio (how far does the cage and pulley wheels move for a given amount of cable pulled by the shifter). If this amount of cable-pull lines up with the amount of cable-pull per click/increment of an indexed shifter and the spacing of the rear sprockets that you're using, then you're in business to use indexed shifting. All Shimano rear deraillers and rear shifters built since the advent of indexed shifting are compatible (same cable-pull ratio) except for pre-9-speed Dura Ace. So a 105 rear derailler that originally came with 6-speed down-tube shifters and 6-cog freewheel will work with 9-speed cassette sprockets and 9-speed STI shifters.
With friction shifting, you don't have these compatibility worries because there are no increments that you need to line up. Anything can be used with anything if you're running friction shifters, pretty much.
"c" is not a unit that measures tire width
High Octane
Quoted: 5 Post(s)
I do agree...
But I ran on to this Dura Ace AX rear der and it is indexed. Shifter is friction but the der is indexed to 6 speed. So I'd say all rear derailleurs works with friction shifting exept for this model. I'm not sure how many different AX models came out but this particular derailleur I got is indexed. No matter how much I fine tune my friction shifting, the der guide will line up within the 6 indexed stops.
I only have 1 AX rear der so I can not compare how the other AX works.
Anybody out there with DA AX rear der care to chime in?
Do your der have those positive stops that makes friction shifting annoying?
fishologist
2007 Leader 736R
2007 Leader 736R
High Octane
Quoted: 5 Post(s)
By the way, indexing happens at the shifter side, except for this Dura Ace AX rear der.
So when you buy any XT stuff, it is indexed at the shifter and the deraileurs will work with either friction or indexed shifters.
By the way, some will claim that the "6-speed" 105 derailer will not function properly with 9-speed equipment, supposedly due to the cage being too wide. Nonsense! I'm tempted to use my 6-speed 105 derailer with new 10-speed 105 equipment, just for laughs (and because, hey, why the heck not?). But then I come back to reality - even "cheap" 10-speed 105 is way outside of my budget!
