flat tire
flat tire
hey-
anybody have any idea why every tube i put into my tire has a slow leak?
it has never been a big deal because i was constantly on it, but i went back to ride after a couple weeks off and it was totally flat.
I always noticed it had the slow leak, i've had about 5 or 6 tubes in there, and they all have done it (except maybe the first). Could i have damaged the rim in some way the first time? any thoughts? thanks.
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
mebe cause tire has sharp object stuck inside it
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
news flash this jst in all prest valves seep
now for the shock and awe
THIS SPACE FOR RENT
Yeah, but they usually don't go to dead flat in a few weeks. This kid has some glass or something in his tire.
Paste Taster
yuppo or a brad nail tack wire brush peice of metal glass residue inside the casing
I know I had em all
I know I had em all
Cornucopia of Awesomeness
I really don't think there is a sharp object in it. I replaced the tire after 4 flats in a few months after my first flat.
Meaning I had the bike for about 4 months, 1st flat. Then 4 more after that first for the next few months. Changed tire, only 1 or 2 flats for the next 8 months.
Things were going smoothly, but still slow leak. Slow enough where every 3 days I have to re-inflate because it is too low. I know there is gonna be some leak, but that seems excessive, no? Also,
I've used a bunch of different tubes, but the one in there now is from iro.
And it's in the ss/fg forum because I ride a fg and it's the only forum I really use.
i'll check the tape, although i don't have any experience with it so, i'm not sure i'll know what to look for. just anything poking through?
thanks.
thanks.
antisocialite
thanks.
thanks.
THIS SPACE FOR RENT
Also feel around at the valve stem hole and see if the drilling is rough. Not as big of a problem with presta, but a burr on the inside could be doing you in. It could be your tire installation technique as well, but after this many iterations I kind of doubt that you're pinching it the same amount every time to get the same slow leak.
Strange As Angels
Originally Posted by baxtefer
or bad rim tape.
Arizona Dessert
Liked 2,169 Times
also (if you unlikely have the four old tubes) blow em up all bulgy and try and find if theres a leak - put em in tank of water - then check if the leak is in the same place, then check if in same place if inside tube (rim/rimtape problem) outside (sharp in tire) or sides maybe double (pinch) very unlikely the later if a very slow leak.
al
al
Paste Taster
also try getting a valve hole boot for your rim it could be you aretightening the little valve ring too tighta gainst the rim and causing a leak at the base of the valve
took tube out, checked it. not a tape problem. no hole in tube. didn't tighten valve ring as much, i'll see how that goes.
i don't have any of the old tubes because they popped and i've replace them. i don't mind the slow leak so much, as it's more a pain. and i can't seem to ever get the tire inflated back to where it was when i first had it. thanks again.
Geez people, theres nothing wrong with his tires, tubes, rim tape, or anything. He said it deflated over a couple of weeks. Ever notice that a balloon will slowly deflate over a period of several days....well tubes do that too..its perfectly normal. They are not perfectly airtight.
To the OP: There's nothing wrong with your tubes. Save your money and stop buying tubes. You should top off your pressure every week or sooner if you are particular about your tire pressure. The reason skinny little road bike tires deflate rather quickly is because of their small volume. A small amount of air loss will quickly lower the pressure. You may notice that mtb tires will hold their pressure for longer, and a car tire will hold its pressure way longer. Thats because these tires have much much more volume than a skinny road tire and a lot more air needs to leak out before you will notice a pressure change.
yeah, air leaks out constantly, but tires should not be "TOTALLY FLAT" after a couple weeks.
700x23c tires with regular butyl tubes inflated to 100psi will drop down to maybe 80-90 psi over the course of 2 weeks.
and yeah Retem, theis has nothing to do with presta vs. schreader vales
no it's not normal, it didn't happen until i changed my tire the first time. and i'm not replacing them because of this, i'm replacing them because they've popped. not because of this, but they've popped.
and it doesn't happen to both tires, just the back one.
If they popped you should systematically take off the tire and remember how the tube was in the tire. Then take a close look at the tube and see where it popped, on the inside, on the treadside, etc. Once you find where the tube blew out, look back at the tire or rim in the vicinity of the hole and find what is causing the tube to blow. If you are using wire bead tires I would suggest taking a careful look at the bead in the area of the hole because that could be the cause. It dosen't take much for the wire bead to put a hole in the tube. If you can't find the problem just buy another tire because at $4 a tube you will quickly eat up the price on the whole rubber part (tire,tube) of the rear wheel.
Pretty elementary really.
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
Forensics are the key. My order of checking goes rimtape, tires, tools (I once tore a tube by using a screwdriver as a tire lever, stupid). Get your popped tubes and find where the leak is. I like to pump 'em full and then hold them near my lips to find the leak, it's less mess than the water way.
The Legitimiser
Bikes: Gazelle Trim Trophy, EG Bates Track Bike, HR Bates Cantiflex bike, Nigel Dean fixed gear conversion, Raleigh Royal, Falcon Westminster.
Liked 5 Times
It's also possible you're damaging them on install with your tyre levers. I'm great at that.
sorry, i said they popped in unrelated events to this problem. glass, a missing cobble stone, metal shard, etc.
I checked the tape (in perfect condition), I checked the tube in water (no leak), and I checked the tire (nothing I could see or feel). The tube itself has NO HOLES in it, so those are not the problem.
I wouldn't be surprised if it was my fault while installing them, except the majority of them were changed in shops.
So, the best idea so far, is the valve ring, and as I've said, I loosened it and will see how it goes. If that doesn't work, i don't know. I still don't know what a valve hole boot is.
and thanks again.
and thanks again.
if there's no hole in the tire and its still completely deflating (not just getting kinda squishy) after a couple days then it sounds like you ended up with a batch of tubes with leaky valve cores.
