freewheel removal
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
freewheel removal
I picked up an ENO freewheel on craigslist the other day. I have a free/free Surly hub, so I just greased up the threads on the unused side and threaded on the ENO. Still, it's time for my crappy Shimano to go. There's no sense running two 17t freewheels.
I picked up a freewheel tool to get the Shimano off but that and a crecent wrench aren't cutting it. I found this on the Park tool site. If I'm understanding correctly I want to secure the freewheel tool against the freewheel with the axle nut, then grip the tool in the vise and rotate? Should I try a longer wrench with the tool first?
What's my next step if this doesn't work? (Yes I did grease the Shimano freewheel and hub threads liberally when installing). I don't want to **** up my hub or my wheel, and while I don't technically HAVE to do this now I'll need to do it eventually.
TRUED 'TIL DEATH
I've seen the LBS get the tool on with the wrench, then put the axle nut on, put the wheel on the ground standing, and just give the wrench a swift kick to loosen it up.
MADE IN HONG KONG
Bikes: some but not enough
Clamp the freewheel tool in a bench vise and turn the wheel like a steering wheel on a Mac truck. Note, you must take great care to push down on the dogs while you turn the wheel or the tool will "cam out". This will ruin the tool by either rounding the edges or snaping the dogs off.
Overall, this should be an easy operation.
MADE IN HONG KONG
Oh right, just re read your post. good idea to hold the tool in place with the axle nut if you can. But the easiest thing to do is to use a bench vise....which you have access to.
Well I got stuck at work tonight. Maybe tomorrow.
aspiring dirtbag commuter
yeah if your a big fella or just ride hard these things can really gets stuck on...
i destroyed the small vice in my garage trying to remove my last one. luckily the shop had a really big vise and we were able to pop it off. not without a considerable struggle though.
The Legitimiser
Bikes: Gazelle Trim Trophy, EG Bates Track Bike, HR Bates Cantiflex bike, Nigel Dean fixed gear conversion, Raleigh Royal, Falcon Westminster.
Liked 5 Times
I hold the rim, and use a giant pair of stillsons to turn the tool. The trouble I have is that as you loosen the freewheel, it tightens the wheelnut you have holding the whole thing on the axle. I have to stop about every 1/4 turn to slacken that off, and it makes me unhappy inside.
antisocialite
axle nut is the way to go. if it's stuck i'll hold the wheel with my hand and stand on the wrench. usually works, not always though...
to be fair that was on a stuck bb fixed cup. and yes, i was turning it the right way...
IMO, I would never NOT use a benchvise as the method of removing. When you are pressing down on a wrench while the wheel is standing leads to a stripped tool, or worse, a stripped or damaged freewheel because there is very little pressure making sure the teeth on the removal tool are engaging properly.
domestique
Bikes: 1977 Raleigh Professional, 1997 Milano 3v, 2004 Surly Karate Monkey, 2007 Surly Crosscheck, 1984 Hutch Pro Racer
antisocialite
Originally Posted by Snordalisk
What kind of a wrench is that? Hope you didn't bang into something in a nasty way when it broke!
i was standing on it, and luckily my foot just fell to the ground when it broke. it did make a nice sound when it snapped and clanged around on my balcony though. i got several shouts of "everything okay?" from the neighbors. they thought the broken wrench was pretty cool...
