New suspension fork
Seek the Joy
New suspension fork
I have a 2006 rockhopper, and the fork is pretty pittifull, i was wondering what forks yall would recomend in the same travel range as the stock rockhopper fork, id like to save up and get a fork that i will like enough to keep when i upgrade my frame, but i dont want to spend 500 dollars on it.
Still kicking.
Reba SL $450
Appreciate the old bikes more than the new.
Flatland hack
Recon $300
Tora $250
I have a Tora on my RH, and honestly im pretty happy with it. I think buck for buck, its one of the better offerings on the market. Worth looking at if you're on a budget.
Tora $250
Seek the Joy
well of course im on a budget, but im willing to wait and increase the budget to where it needs to be. Im 150 pounds and would like to get a fair amount of travel from the fork. most forks ive seen are too stiff for me, idk, maybe its jsut cheap ones
Flatland hack
Whats your budget?
How much travel do you think you want?
What kind of riding will you be doing?
Seek the Joy
i plan on doing somthing like cross country, but i like drops too, like 2 and 3 foot drops though.
my budget is about 350 bucks probably.
100-130mm?
100-130mm?
Noobhead
Bikes: k2 Zed 4.0
brand new or used?
jenson is selling mx comp for 228 and mx pro for 271
on ebay, $350 is well within the range to get a used reba u-turn air
Bikes: Hecklah
If you search ebay for a Rockshox Tora, you will find a good deal on a Tora Solo SL Air (hint, hint)...they don't make the air sprung version anymore therefore this is probably the lightest Tora that was made. (as far as I know) The others are coil sprung and boat anchors, but they do work well.
I must say, the Tora is a great fork for the buck. The Motion Control damper actually works, the 32mm stanchions are stiff, the rebound is effective, the lockout works like a champ...it's just a great budget fork. It's basically a Reba with steel stanchions (instead of aluminum) and the external floodgate adjustment. I'm pretty sure that everything else is the same.
The only reason there's a Tora Solo SL Air on eBay right now is b/c the owner just had a new kid and is parting out his/her hardtail. (boohoo)
