Your century bicycle(s)
#327
Bye Bye
It will be going to eBay next week - I upgraded to something a bit bigger for overnights with gear.
Its a great bag for cold centuries, doubles, brevets, and around town. Comes on and off the bike easy with the SQR block. I had an extra block on my other bike so I could swap it easily.
#329
Bikes: 2008 Turner Spot, Berg Ti Cross, 2011 Karate Monkey
Carradice SQR Tour.
Just Riding Along
Just Riding Along
#330
This is Shangri La
Quoted: 5 Post(s)
You touched on a thought I had recently about these large seatbags. From my perspective, the capacity need is either a) multi day b) overnighter or c) single day. If you're 'c', then I don't see the need for the seat bag in your picture, as one could be prepared with std seatbag+jersey pockets. For b) the Nelson Longflap or a single pannier seem the way to go with ultralight/compact camping gear. Sounds like you're honing your strategy for an overnighter - check dave's pic over on surly blog for more inspiration.
#332
My Tom Bromwich Mixte...
Two front lights, one rear light, one side/rear light, most visible while being overtaken.
I have a basket clip on the front which I use when doing short shopping trips into the city.
#333
Bye Bye
I picked up the Camper for a self supported 300k (actually its turning into a bit longer than a double century) through the ADKs and to follow up with some overnights where I'll be carrying cooking gear and a hammock. One could probably tour indefinitely out of the camper with the addition of an h-bar bag or a small front rack.
The bag is now on eBay.
#334
put me back on my bike
I have a carradice bag like the carradura. I say "like" because I've had it over 6 years and I can't be sure of the name anymore. With 2 mounting blocks it's easy peasy to switch bikes. I also modified a little bag to take the carradice support, and it's great for shorter brevets.
The carradura served me well for PBP though the metal frame popped its welds and had to be held together with zip ties until the end.
Once home I re-welded it, but with higher lugs so the bag now sits higher behind the saddle, more clearance above the rear wheel.
The older I get the better I used to be.
#336
David H.
Bikes: 92 Koga-Myata road bike, 07' Gunnar Rockhound 29'er mtb, 06' Kona Cinder Cone 69'er Gravel Bike, Windsor 8 spd IGH steel commuter, 99' Trek 520 tourer, Minnesota 1.0 Fatbike
Quoted: 8 Post(s)
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
All of them except the TT bike and the fixed gear.
You could get lost and die.
You could hit a tree and die.
#341
Bye Bye
TA Carmina, 94 BCD so I can run a double with the smallest ring a 30 and the largest a 52. Currently like the 32-46 combo I have on - but have run it as a 34-50 and a 32-48.
They have a removable spider - so I can keep the cranks and change it to a triple, or change it to a 110 spider. Really nice crank.
#342
This is Shangri La
Awesome! Thanks. That goes on my wish list for sure. Seems like a great way to have gearing for all kinds of riding (standard double, compact double, triple). Just choose your weapon (read: gearing) for the conditions.
#343
Bikes: Trek 7500 bought 6/13/06
My Trek 7500 Hybrid (2006 model). Riding in my first century on 8/23/08 at the H.O.T. 100 in Tennessee. Can't wait.
#344
This is Shangri La
The long wait is over. After five months waiting (due to a vacation I took that delayed things). The frame is Columbus steel and designed to be an all day bike, century/double century, brevet, light touring. I had rack mounts added to the frame and fork and third bottle mount. The fork mounts are designed for Tubus Duo. Maiden voyage is tomorrow after work.
Enjoy the photos, sorry the quality kinda sucks.
I found this bottle of beer with a perfect top for my new build. The colors match almost perfectly. The beer is actually killer double Belgian Ale too!
#346
#348
Liked 13 Times
I run a 46-30 with a TA crank and went through every derailleur in my collection trying to get something to work. None of the modern stuff did the trick, including Campy Record and Shimano Ultegra. Mountain bike derailleurs were even worse. I finally tried a thirty year old Campy Super Record number out of desperation, and it's been flawless.
#349
Bye Bye
the lbs that built it actually set up a marginal chainline. when i pulled the bb i sorted that out and had much better f der. shifting.
#350
