Cog advice...
Old 02-20-07 | 05:54 PM
davidmcowan's Avatar
Live Deliberately.
Bikes: CETMA Cargo, Surly Big Dummy, Surly Straggler, Rocky Mountain Blizzard
Cog advice...
Just picked up a set of wheels with a flipflop hub today. I've been riding with a surly cog loctite/jbwelded on a freewheel and wanted to get a flip flop in case my legs wear out on me. I've been riding 42-16 with some ease for a little under a year. These tires are lighter and thinner than my old 27's so now I'm wondering about the cogs I should get for these wheels. What brand should I use? (I won't be heading to the velodome but I do use my bike as my primary vehicle) Should I run something higher? lower? Does my freewheel side need a smaller or larger or different cog or is it all interchangeable? Will spacing the tires be a cinch or should I set aside many hours? Any suggestions for places to get good deals on these cogs?
If you have an answer for one or all of these questions I'd be a happy man.
Thanks...
davidmcowan is offline
Reply
Old 02-20-07 | 06:09 PM
Brian Ratliff's Avatar
20 Anniversary
Bikes: Three road bikes. Two track bikes.
I have a Surly cog which seems pretty good. Some of the cheaper cogs seems to be offset a little so the chainline isn't perfect. I also found that a prime number of teeth on the cog (i.e. 13, 17, 19, 23) will enable you to use any chainwheel size without constantly wearing on a single patch or set of patches on tire (this is the "skid spot" that you'll hear about here).
As for gear ratio, I currently run a 48x17, though a 46x17 (roughly like the 42x16 you currently have) was good too.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Brian Ratliff is offline
Reply
Old 02-20-07 | 06:11 PM
isotopesope's Avatar
shoot up or shut up.
20 Anniversary
Bikes: yes please.
i prefer eai cogs. check out salvagetti at 1234 speer. scott carries lots of fixie stuff.
isotopesope is offline
Reply
roadfix's Avatar
hello
20 Anniversary
Get EAI cogs. ...no worries.
roadfix is offline
Reply
Old 02-20-07 | 06:15 PM
mihlbach's Avatar
20 Anniversary
I've used EAI, Surly, and Soma cogs. I haven't been able to detect a significant difference in performance between any of these. All of them are good quality, as are Duraace and PhilWood cogs. The most important thing is not to cheap out and get a no-name or low quality cog...too many horror stories about these stripping your hub.
As for gearing, thats a personal choice. If you are going with a free/fixed flip flop setup, its typical to gear the fixed side a little higher because you have to pedal down hills.
mihlbach is offline
Reply
Old 02-20-07 | 08:19 PM
via hiptop
Bikes: wooden lightning, cyclepro conversion, varsity beater, nishiki conversion, fuji conversion
I'd like to learn more about the mathmatics of gearing. I just played around with cassette cogs on a 9 spd huub till I figured out what I wanted. The math part is probably pretty limited, but it's still very intresting. I never thought of the prime number thing before, or spreading the wear from skids with math. Thanks.
iamarapgod is offline
Reply
Old 02-20-07 | 08:25 PM
Read this. The overall result proven (that's the sentences labelled (1) and (2)) will be clear, even if the proof isn't, as long as you know how to reduce a fraction (wikipedia will help if you forget).
https://www.bikeforums.net/singlespeed-fixed-gear/242123-skid-patch-theorem.html
Then go here and fool around for a while.
https://www.basementfreaks.com/members/karl/gearing/
mander is offline
Reply
Old 02-20-07 | 08:47 PM
cab horn
20 Anniversary
Bikes: 1987 Bianchi Campione
That's not even close to a proof. The very first statement is already false, integers include all whole numbers, negative, positive and zero.
Now i'd like to see someone produce a cog that has -14 teeth or 0 teeth. Pretty lame attempt if you ask me. If you're going to pretend to be smart at least do it properly.
operator is offline
Reply
Old 02-20-07 | 09:13 PM
THIS SPACE FOR RENT
Play around with a gear calculator, but you can probably push a marginally taller gear with thinner tires and lighter rims, so maybe try 42x15. As for brand, if you can buy local get whatever name brand is around (EAI, Dura Ace, Surly, whatever), if you have to buy online dura ace is great and cheap, rockwerks is rebadged surly and are also perfectly fine.
I'm not sure what you mean by "spacing the tires." As for the freewheel size, if you want to use it to bail out on hilly terrain I would go with a 1 or 2 tooth larger freewheel, that way you can climb up in a little lower gear and then coast down. Those of us who live somewhere flatter usually go with the same gearing.
Landgolier is offline
Reply
Old 02-20-07 | 09:38 PM
...by acting like a prick? i didn't read the proof, but the result is clear enough and the guy did say he wanted to know more about the mathematics of gearing.
Instead of harshing the vibe you could post in the skid patch thread and either have the guy change "integers" to "natural numbers" or explain why you think the skid patch theorem fails in the case of "impossible" cogs. The theorem is linked to off the diy sticky so that would potentially be helpful.
mander is offline
Reply
Old 02-20-07 | 10:04 PM
Live Deliberately.
So every step down from 16 is actually a higher gear? 15 would be a higher gear? is 14 just ridiculous to try and ride around on?
I'm not sure what you mean by "spacing the tires." As for the freewheel size, if you want to use it to bail out on hilly terrain I would go with a 1 or 2 tooth larger freewheel, that way you can climb up in a little lower gear and then coast down. Those of us who live somewhere flatter usually go with the same gearing.[/QUOTE]
Spacing the tires was refering to getting my back cog to line up with my front chainring. Don't you have to use spacers or something? I don't know the process but I imagine it couldn't be that hard. Any links to how to do this?
Reply
Old 02-20-07 | 10:14 PM
surging w slash energy
the only thing from the other thread that is important:
you just reduce the fraction of the chainring over the cog, and the denominator is the number of skid patches. If that number is odd, and you happen to skid or skip both ways (right foot forward, left foot back, and the other way around) you double the number of skid patches. There's a big difference between 34 or 38 patches vs 1 or 2.
NNNN is offline
Reply
Old 02-20-07 | 10:28 PM
On my formula hub, I have a 17t Surly cog
On my phil fixed/fixed I have a 15t dura ace and a 17t EAI.
I haven't had those last two cogs for too long, but I haven't heard anything bad about them.
As for my Surly cog. No complaints. I've had it on for over a year and there is no visible wear. I've worn chainrings down, but the cog has been in nice condition.
Don't go cheap on your back wheel.
BuddyMike is offline
Reply
Old 02-20-07 | 10:31 PM
Live Deliberately.
Dura Ace seems to be the cheapest out there....is that a representation of the quality of Dura Ace? Why should I pay more for something like Surly? Wouldn't it be smarter to use the money to get myself an extra cog or two so that I can play around with them?
Reply
The skid patch theorem says it's the # of chainring teeth whose oddness or eveness makes that difference. Is that wrong?
mander is offline
Reply
Old 02-20-07 | 10:46 PM
Dogbait's Avatar
lunatic fringe
Bikes: 1980 Schwinn World Sport, 1982 Schwinn Super Le Tour, 1984 (?) Univega Single Speed/Fixed conversion, Kogswell G58 fixed gear, 1987 Schwinn Super Sport
According to a mechanic at a bike shop in Portland that does a lot of work on fixed gear bikes, EAI is the best... longer wear, nice threads. Next, but close behind, comes Dura Ace. He said they will last almost as long as EAI but the difference would not be all that obvious to someone who does not ride all day, every day. He said that Surly was not worth considering due to it's being too quick to wear out... nicely made though, just too soft.
Dogbait is offline
Reply
Old 02-20-07 | 11:43 PM
andre nickatina's Avatar
not actually Nickatina
Just curious, which shop / mechanic?
andre nickatina is offline
Reply
Old 02-21-07 | 12:11 AM
eaglevii's Avatar
FG 48x17
Bikes: Lemond Road, IRO Rob Roy, Rush Hour Fixie
I ride a 46x16 and a 48x17, that seems pretty good to me, but Albuquerque is not super hilly within the city (not flat either). I found that anything higher than 48x17 got pretty bad in a strong headwind. Use a gear inches calculator to get an idea of how much of a difference these would be from your current set up. As someone else mentioned, if you have a road bike, find cog/chainring combos that match the gear inches/gain ratio of the fixed ratio you are contemplating, and try it out.
I've used IRO and Surley cogs, both with good results. Be sure to get the correct width cog, in my experience Dura Ace 1/8" cogs are a little thinner than others, and can be mistaken for 3/32" by some know nothing LBS workers.
On my bike that has a freewheel, I went with the same size as the cog, because I enjoy that ratio. I think it would be more practical to make it a little larger, since you'll be using it when you're tired.
eaglevii is offline
Reply
Old 02-21-07 | 12:36 AM
Dogbait's Avatar
lunatic fringe
I don't know the mechanic's name but the shop is Bike Central.
Dogbait is offline
Reply
Old 02-21-07 | 12:48 AM
Could very well be Dean than, that guy's legendary.
Reply
Old 02-21-07 | 06:26 AM
Should be out Riding
Bikes: Bob Jackson Vigorelli
Looking at each column in the table I would say it is the cog not the chainring.
EDIT: I was thinking about this a bit more. The best way to maximize the number of skid patches is to use a chainring and a cog that are prime numbers this will give you a total number of skid patches equal to the number of teeth on the cog. Since the max number of skid patches one can have can not be greater than the number of teeth on the cog, I would say the cog dominates.
However, upon further inspection I also realized that one can have a cog that is not prime but does not divide the chainring and still obtain skid patches equal to the number of teeth on the cog. In other words the cog and the chainring will maximize the number of skid patches if they are relatively prime.
Also, I just found this.
lvleph is offline
Reply
Old 02-21-07 | 07:14 AM
Aeroplane's Avatar
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
Surly drastically changed their cogs a couple years ago. They are now much higher quality, and wear very well.
Aeroplane is offline
Reply
Old 02-21-07 | 08:44 AM
queerpunk's Avatar
aka mattio
Bikes: yes
i've produced a 0 tooth cog.
it's sitting on your desk right now.
here's a picture of it:
queerpunk is offline
Reply
Old 02-21-07 | 08:59 AM
Nice try but you lose.
Just because a -14 tooth cog doesn't exist does not effect the validity of the proof. Since the set of real world situations is a subset of those for which the proof is valid it is fine.(If you really wanted to you could think of a negative gear ratio one in which the chain was crossed.)
dutret is offline
Reply
Old 02-21-07 | 09:14 AM
+Group theory*
lvleph is offline
Reply
