Energy Calculator tells how many calories you burn each day
Parttime Member
I was wondering how many calories I burn each day with respect to my height/weight/age and my activity level. I ran across this web-based calculator. Give it a try!
https://nat.crgq.com/energy/daily.html
Thedailyplate.com and sparkpeople.com also have very good, intuitive calorie calculators that they apply to your profile when you sign up.
I reviewed a few such calorie counting websites, if you're interested, look here.
Third World Layabout
Bikes: Cannondale F900 and Tandem
Quoted: 397 Post(s)
Liked 32 Times
Interesting, it says that I should consume 3500 calories a day - no wonder I am dropping about a pound a week - after I bottom out (just a few more pounds) I am assuming there will be pies and such in my future.
Perineal Pressurized
Got to the point I started buying stuff in smaller waist sizes.
Stopped traveling, started hanging around the house more, snacking with the grandkids (somebody had to finish off those half eaten pop tarts), wasn't able to do the long rides.....basically 180 degrees.
Faster than a cheeseburger disappearing into my mouth, my belt is out a notch, my pants are suddenly tighter (honey did you wash these in hot water, again?).
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
The Other White Meat
Bikes: Raleigh Sports 3 speed, Torker T-530
I gave it the same data as my doctor's Tanita Body Composition Analyzer. It says my maintenance calories are 2806. The doctor's device says 2823. I'd say they're virtually the same for one who is going to live in the real world and not consume a carefully calculated formula as a diet.
Quoted: 397 Post(s)
Liked 32 Times
What is weird is I know I don't eat anything near that amount of food - probably more like 2500 calories - no more than that. And, I tend to drop 1 pound a week. It is very possible that as our conditioning improves, our efficiency with calories does as well.
How do you know you don't eat that many calories every day? Try using thedailyplate to count your calories and be honest ... it's really quite a lot of calories, at least it was for me.
My idea of fun
Bikes: '06 Litespeed Tuscany, '02 Kona Lavadome, '07 Giant TCR Advanced, '07 Karate Monkey
Quoted: 41 Post(s)
Liked 59 Times
Bikes: 70s or 80's Panasonic Villager III
The only problem is, that the weight that they ask you is not your lean body mass. What they are telling you there is what you need to keep what you've got now. I work 10 hour days 4x a week as a butcher, and on those days I get about 1 hour of cycling in. It told me that I need to intake over 5600 calories on those days. If that were true I would weigh 30 lbs lighter than I do now.
If you can get your Body Mass Index(BMI) taken. It will show you the % body fat that you have, then you should use the calculator based on that weight when you have taken off the body fat from your total weight. Also remember that these are your absolute maximum needs.
gearhead
Yep, I smell something fishy here.
I drive in the car 3 hours a day, and sit at a desk for 8+, with winding down at home at night being reading, watching tv, etc.... no exercise lately, as i'm recovering from an injury. 328 lbs. at 5'10" and I should eat 4412.4 kcal a day to maintain???? If I ate that much I'd be gaining like crazy....
I was 326 (300 even today after almost 8 weeks) and it estimated me at 3730cal/day. (6'0", 326.5lbs, mostly sedentary with .5 hours light or medium activity/day ... walking to work, walking the dog and riding bike on weekends).
I've been counting calories (which sucks, but it works very well) and keeping it under 2000 calories give or take. the average is very close to 2000.
So my estimated daily deficit is 1730 calories/day, 12110 calories/week
Estimated pounds lost/week
To find how many pounds I should be losing a week, I divide the estimated weekly calories needed to maintain weight by the number of calories in a pound:
12110/3500 = 3.46lbs/week
That means, based on the estimate I should be losing about 3.46 lbs each week.
Actual pounds lost/week
So looking at my progress (which is independent of the estimated calories needed measurement) I find that since January 3rd (start date) it's been almost 8 weeks (two days short, a pretty good sample size), and I've lost 26.5 lbs. The number of pounds lost divided by the number of weeks gives me pounds lost per week:
26.5/8 = 3.313lbs/week
Comparison of Estimate to Actual
That's not too far off the what the estimate suggested (3.313 vs. 3.46). The difference is 73.5 calories/day; within less than 2% of my actual caloric needs to maintain weight. That's pretty good for an estimate!
Just a note, the estimate is actually more accurate than these numbers suggest. My initial estimate was 3730; but if I repeat the estimate today, now that I weigh less, it tells me that I need 3500calories/day. The "real" results are actually an average between those two estimates! The accuracy is VERY high.
Bikes: RANS Dynamik
I gotten figures from other sources - If you're honest this one's pretty much right on...
Become a Registered Member | Community Guidelines
My Bikes: RANS Dynamic - RANS Cruz - RANS Fusion - Downtube IXNS
...............Read two Crank Forwrd Reviews!
