Vintage Brake-Lever Installation, No Brake Release Installation
Bikes: No bike at the moment; In process of building it.
I'm using vintage Dia-Compe Gran Aero brake levers (all white, they're sweet ). But they don't have the "quick release" button on the levers so I can't get any slack when setting up the cable on the calipers. I cannot get the rear brake tight enough at all. I pull the lever and it isn't enough power to do anything to the wheel in any meaningful way. I have been thinking I might use some locking needle nose pliers to hold the cable inside the brake hood/body, set up the caliper and pulling the cable out the front and sliding it into the cable stop holder (it has a slit in it).
Thoughts?
Thoughts?
You Know!? For Kids!
I use a clamp to hold the caliper where the brake pads are almost touching the wheel. I then pull all the slack out of the cable and tighten the pinch bolt on the cable. Release the clamp from the caliper and you should be done.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Remember Wool Shorts?
Bikes: Gios Torino, Lemond Zurich, Giant
Loose Screws formerly known as "The Third Hand" company (www.loosescrews.com) used to have a great t-shirt that said "What's the sound of a third hand clapping?". Only bikers knew what it meant.
You can always use a toe strap to close the calipers or a piece of rope or someone with strong fingers to hold it down.
You should check Park tools website, they have demos and stuff there.
Liked 5 Times
If you need just a little extra squeeze on the brakes to get them set right and you don't have the lever quick release, you can remove your wheel and squeeze the calipers together as much as you want. Using the quick release on your brakes (assuming you have one) does about the same thing.
If you can't get the cable taut enough, you may have some constriction in the cable path (housing, kinking, dirt, etc).
/trying
I have the same problem with an old set of MAFAC centerpull brakes. No release or adjustment on levers or calipers. https://www.nashbar.com has something they call a CABLE ADJUSTER, but I can't see how it works from their illustration. They look like a couple of short round tubes with several plastic ferrules.There is no description of how it works or how or where it is installed. May solve our problems. Has anyone used this item and can tell us something about it? I may take a chance and get a couple.
I believe that you can install them wherever you have cable housing. you choose the correct size threaded insert for your cable/housing combo and then cut the housing and install them inline. They work the same as the barrell adjusters on your derailers work. By screwing the inserts in or out, you effectively lengthen or shorten the cable housing. Since the cable length is constant, lengthening or shortening the housing will tighten or loosen the caliper.
Screw your barrel adjuster all the way in, release the quick release on the brake caliper if you have one. Hang a heavy pair of vise grips on the end of your cable (protect your frame), squeeze the brakes together with one hand as needed (tug the vise grips), tighten the cable clamp with the other. release the vise grips, return Q/R and adjust with the barrel (if req'd).
