Working definition of "Vehicular Cycling"
#126
Bikes: Road, Mtn, Tandem
Originally Posted by Helmet Head
... fsdt (faster same direction traffic)... In cases like this ... it prevents oncoming traffic from passing.
#127
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,530 Times
Originally Posted by Bruce Rosar
IMHO, using prevents in this context overstates your case somewhat. While a wide vehicle (such as a car) is easier for other road users to see than a narrow vehicle (such as a bicycle), approaching traffic (from any direction) can't actually stop a someone from attempting a pass (although it would be less likely that they'd try).
#128
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
One can not make any judgement about that photo due to the presence of the vehicle (bike or car) that it was taken from. That changes the situation completely. Maybe they always ride in the so called 'margin' but that can only be a guess.
Al
Al
#129
Yea. People. To another room with you all if you want to keep on your "fsdt" topic.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
#130
Originally Posted by Brian Ratliff
Actually, the way that vehicular cycling is defined in the OP (which is what this thread is about), it doesn't matter what the road conditions are, beyond that those cyclists are in "lane sharing mode" and what you are advising is for them to be in vehicular mode.
Faster, same direction traffic is irrelevent in defining "vehicular cycling". Vehicular cycling is a tool in the tool box that you might pull out in the presence or absence of faster same direction traffic. But application of that tool to specific road environments is best done in a different thread.
#131
This is yet another reason why I believe the presence or absence of fsdt is such a critical factor in determining where I am positioned. When fsdt is present, it acts as a "cover". In cases like this (rural 2 lane highway with dashed center stripe) it prevents oncoming traffic from passing. When fsdt is absent, you have to take an assertive/conspicuous position to create your own cover not only to prevent oncoming traffic from using your lane to pass slower traffic moving in their direction, but also to inhibit cross traffic from crossing in your path.
Edit: in my defense, technically, "hinder" is supposed to be a synonym for prevent, and "hinder" would be an appropriate word to use here, but prevent does imply "not allow" to a greater degree than I intended to convey.
Edit 2: I changed the first one back to prevents, since that's reasonably accurate, and changed the second one to hinder.
#132
Al
Al
However, IF that exemplifies how they are positioned when fsdt is absent, then my comments apply.
#133
I think the problem with the term "vehicular" is that the only (non cycling ) "vehicular" experience the vast majority of the public has had does not include operating a slow moving vehicle.
#134
Again, this is all very understandable because most people's exposure to anything they associate with the term "vehicle" is almost thoroughly dominated by cars. So when they hear or read "vehicular", they think "like a car" or "pertaining to a car".
Edit: Anecdotally, the occasional commercial truck driver who posts here seems to have less of a problem with associating the behavior of drivers of slow moving vehicles with the term "vehicular" than does the average person.
#135
Dominatrikes
Bikes: Catrike Pocket, Lightning Thunderbold recumbent, Trek 3000 MTB.
It's hopeless, Brian.
Let's just adopt your definition of vehicular cycling as part of adaptive cycling and be done with these jokers.
#136
I think the problem with the term "vehicular" is that the only (non cycling ) "vehicular" experience the vast majority of the public has had does not include operating a slow moving vehicle. Therefore, to them, the legitimate behavior of drivers of slow moving vehicles, including moving aside, using shoulders and sharing lanes in order to allow faster same direction traffic to pass easier, when safe and reasonable to do so, does not seem "vehicular". But such behavior for drivers of slow moving vehicles is most certainly vehicular, and most if not all legal manifestations of the vehicular rules of the road mandate it. To eliminate it from the "definition" of "vehicular cycling" does reflect the common sense interpretation of the term vehicular, but ignores the operational and physical characteristics of the bicycle that make the vehicular rules of the road that apply to drivers of slow moving vehicles so relevant to bicyclists operating in traffic on roads in accordance to the vehicular rules of the road.
The problems you speak of are largely political. I sympathize because most of the battles cyclists have fought with governments have been political. The terminology from these battles have political meanings which conflict with technical meanings, and this is part of the problem.
The fact that the term "vehicular" has an understanding in common vernacular that is somewhat separate from how some of us use the term is what is at the center of all this. The OP definition takes this common vernacular definition and codifies it into the technical language. The issue I disagree with is that the term "vehicular cycling" need take into account any operational characteristics of bicycles. I guess I am taking up your position in this matter, that speed and size of the vehicle don't matter, in the context of vehicular cycling (in the OP definition sense).
The very point of redefining "VC" is to get away from this battle of words between "pro-facilities" people and "anti-facilities" people. Look at the heckling from galen, for example, I get for a simple tightening up of the definition. I want a true discussion of the effects of how cyclists ride on the road. The effects on safety, the effects on the traffic system as a whole, and the effects on cyclist and driver's perception of cycling. It might be expedient for vehicular cyclists to lay claim to the term "vehicular cycling," but realize that by doing this, and combining generalized safe cycling practices in with ideology, you are essentially politicizing a very valuable cycling technique.
The whole goal here is to separate these valuable cycling techniques from the politics. A cyclist who takes the lane through an intersection should not be labeled a "vehicular cyclist." This hypothetical cyclist might take issue with the politics of vehicular cyclists, and get the idea that he shouldn't use any of the techniques that John Forester popularized, because then he'd be a member of a group against his will and opinion.
To separate these cycling techniques from politics, the definition has to be tightened up to the point where it only includes the basic hallmarks of the technique, namely, taking the lane and destination lane positioning. All the other stuff, like lane sharing or stopping at stop signs, is simply stuff that any cyclist has to do to get anywhere on a bike. I want to separate all this extraneous stuff from the term, so that these uniquely vehicular techniques can be evaluated given specific situations. Why have a war over a word which already has a common vernacular meaning which most of the population will recognize? Why not make the common vernacular meaning the formal meaning. It seems like it'd save a lot of confusion.
#137
HH and I are actually having a pretty good discussion here. Even if the terminology cannot be adopted, it drags a whole bunch of stuff out into the open. Including the heckling, which just goes to show how politicized this term is, and how much need there is for a change of definitions on a broad scale.
#138
Arizona Dessert
Liked 2,169 Times
"Examples of what is not within the working definition of vehicular cycling:
1) riding to the right hand side of the road and sharing the lane. A cyclist traveling in vehicular mode will not share lanes in any way, shape, or sense of the word. "
When you know very well that most folks who consider themselves vehicular in their cycling style do do this? Given this did you expect there would be no friction in your revised definition?
Al
#139
Again, a "vehicular cyclist" is not what I am defining here. I am defining a word to describe a set of techniques which vehicular cyclists and other types of cyclists sometimes use.
Self described "vehicular cyclists" or "folks who consider themselves vehicular in their cycling style" can describe their cycling style as anything they want.
To get what I am saying, ask yourself: what is the hallmark of a "vehicular cyclist"? It is not riding in the margin and letting a car share their lane (using HH's definition for a "margin"). It is taking the lane and not allowing passing, coupled with destination lane positioning.
Lastly, if "vehicular cycling" already has a meaning in common vernacular, why complicate the definition to make it some sort of intimidating "school" of cycling?
#140
I'm glad that someone is still on topic here. Anyway...
But what if we referred to your description in the OP as "Advanced Vehicular Cycling"? OR AVC, to differentiate the subset of VC practices that are not as commonly used by the typical cyclist as are other VC practices.
That way we can say lane sharing, for example, is a VC practice, but it is not an AVC practice (which is not to imply that someone advanced in VC would not use it, just that lane sharing is not an AVC practice), and that using an assertive lane-controlling position (when safe and reasonable to do so), is both a VC practice and an AVC practice.
If we achieve consensus on this, perhaps you can modify the OP accordingly, and coax a moderator to change the title of this thread, and we can stop the arguing over terminology, politics and semantics?
#141
After re-reading your words, I agree with your motivations, and believe them to be honorable. I agree that there are problems with calling a cyclist a "vehicular cyclist" just because he does something that overlaps with the practices encouraged by vehicular cycling education programs. ILTB often makes legitimate complaints about John Forester classifying all cyclists who make traffic errors as not being vehicular-cyclists, as though cyclists who attempt to operate according to vehicular principles never make errors.
However, I disagree with your assertion that sharing the lane is outside the fundamental concepts of vehicular cycling. I observe it to be a very important part of vehicular cycling technique; specifically, I believe that proper lane sharing technique must be explained in terms of vehicular rules, so that cyclists will best understand what side of the lane they do and don't want other traffic trying to use to overtake them depending on their destinations. I view sharing of wide lanes to be a specialized case of the more general rule of sharing a substantial width of unstriped pavement, whether this pavement is a residential street or a wide multi-use path. I view overtaking without a stripe between users as an ordinary part of cycling and thus an essential subject for vehicular cycling to address according to basic vehicular rules.
I also disagree with your assertion that stopping for stop signs and such is obviously something that any cyclist must do to get somewhere on a bike. There are some people who feel strongly that cyclists should not have to follow many of the basic vehicular rules that other drivers follow. For instance, some believe that cyclists should have the right of way over other drivers at intersections, or that cyclists should be able to ride across mid-block crosswalks and that drivers on the main road should yield to them like they ought to yield to pedestrians at mid-block crosswalks. Vehicular cycling as a model of traffic negotiation offers explanations of why these alternate rules are problematic due to the kinematic and dynamic limitations of the bicycle as a vehicle, as well as the limited perceptual and reactive abilities of drivers of cars and bikes. Put more simply, if one enters junctions fast enough to have limited time to see and be seen by other drivers, and one has limited ability to stop instantly and/or back up when things happen unexpectedly, then the normal vehicular rules are safer at junctions than other rules such as pedestrian rules.
These are some of the useful features that I see in the vehicular cycling paradigm and the cycling education programs and traffic laws applicable to cyclists that are based on it. This is why I encourage you to not throw out the baby with the bath water by attempting to define vehicular cycling otherwise.
-Steve Goodridge
#142
1. riding in any part of the lane
2. riding in the right tire track
3. riding in between the tire tracks
4. riding down the centerline of the road
5. swerving in front of passing vehicles to physically "take" the lane (this last definition is also often confused with what HH refers to as dynamic lateral lane positioning)
No one here will argue that destination lane positioning is not part of vehicular cycling.
Go searching for some threads about stop signs or just observe cyclists anywhere on the roads and see how many actually stop for stop signs when they should. Most don't think they apply because they do not see themselves as vehicles. Most sidewalk cyclists don't give a crap about redlights either and neither do most cyclists who I see sticking to the margins of the road at all times.
You can ride a bike without stopping at stop signs or red lights but then it wouldn't be very vehicular. Rarely do you see anyone driving their car with the same disregard for traffic control devices as you see coming from non-vehicular cyclists (except in the case of speed limits but that's another topic).
#143
Originally Posted by sggoodri
Brian,
-Steve Goodridge
-Steve Goodridge
#144
Or, now that we've hashed out whatever we accomplished in this thread, let's leave it as is, and you (Brian) start a new thread entitled "Working definition of 'Advanced Vehicular Cycling'", copy/paste/update your OP, and start from there?
#145
Seems like more reasons to go with "Advanced Vehicular Cycling" or "Advanced Vehicular Cycling Practices".
I suggest we call it something more descriptive and clear, such as "Lane Dominance Cycling". The basic rules of the road, and why it's useful to follow them on a bike, would be outside the scope of a discussion about how to most effectively control a travel lane.
#146
Here's what I propose as a compromise.
Vehicular Cycling (VC) is defined as cycling on roads in accordance with the vehicular rules of the road (as opposed to cycling in accordance to the rules of the road to be followed by pedestrians, or not in accordance to any specific set of rules), including the rules of the road that drivers of slow moving vehicles are supposed to follow.
In order to differentiate the VC practices used by most cyclists from those used by those who describe themselves as vehicular cyclists, the term "advanced vehicular cycling" will be used to describe those practices.
Advanced Vehicular Cycling (AVC) is a group of VC techniques and practices surrounding the adoption by a cyclist of destination positioning utilizing the full width of the roadway.
Examples of what is not within the working definition of Advanced Vehicular Cycling:
1) riding to the right hand side of the road and sharing the lane. A cyclist traveling in advanced vehicular mode is not sharing lanes in any way, shape, or sense of the word.
2) sidewalk or bike path/MUP riding. (AVC only applies on roads used by motor vehicles).
3) two step left turns.
4) simply following the local laws that are contrary to destination positioning utilizing the whole roadway. For example, if the local law tells cyclists to use the sidepath, using the sidepath is still not cycling vehicularly. If the local law demands lane sharing; this is still not cycling vehicularly to remain in compliance with this law.
5) the equipment for traffic cycling
6) the head flicks, hand flicks, winks, nods, pedal cadence, steely eyed alpha dog stares (), etc. utilized to gain a motorist's attention. These will vary according to environment, cyclist, cyclist's mood, etc. [NOTE FROM HH: However, effective communication with other drivers should be recognized as an AVC technique, since most cyclists do this much less than do those advanced in VC).
7) riding to the right in a WOL and sharing this lane with car traffic. This is a working definition, and for reasons of consistency, I have to exclude this from the working definition. WOLs are a special case where lane sharing is explicitly encouraged. This is not an advanced vehicular practice. This is not to say that WOLs are somehow inferior cycling facilities. It is just to say that lane sharing while using WOLs is not an example of advanced vehicular cycling.
8) the basics of cycling, such as riding on the right side of the road and stopping at stop signs. This is to keep the definition precise.What are within the working definition of Advanced Vehicular Cycling:
1) destination positioning at intersections
2) vehicular left turns
3) controlling the lane. (or "taking the lane") when safe and reasonable to do so i.e. not sharing a lane with another vehicle driver by using an assertive "centerish" lane position when faster same direction traffic is not present, the lane is not wide enough to be safely shared, etc.
4) riding in the bike lane.[NOTE from HH: this does not seem to fit the "advanced" notion), I think we should take this one out] This is vehicular because a bike lane, as defined as a traffic lane dedicated to bicycle use (this definition doesn't include those "bike lanes in name only" lanes that DOTs sometimes force on us) meets the requirements of non-lane sharing, and to leave a bike lane means to go through all the procedures used to change lanes in traffic. One cannot, by design move arbitrarily from the bike lane to the adjacent traffic lane because the cyclist does not have right of way to do this. As with the WOL lane sharing designation, this is not to imply that bike lanes are somehow "better" than WOLs.
#147
I don't really care for your "Advanced" modifier as I don't see what borders on pathological lane dominance as a virtue or desirable progression from normal vehicular cycling.
#148
#149
I think you both are still in the box, so to speak. I'm not defining an ideology or worldview here. Within the OP definition, no cyclist is vehicular all the time. It is a name for a grouping of techniques, which center around taking the lane and desination lane positioning.
I am trying to rid the word of ideology. You both are slipping back into redefining this into an ideology which is separate from the vehicular cyclist ideology. This is not an attempt, like the AC attempt, to define a separate ideology to compete or even coexist with the vehicular cyclist ideology.
To put it in bare terms, the term "vehicular cycling" should be formalized to mean (and will be when I speak of the term from now on) "ride a bike like a car", since this is what it means to most people anyway.
#150
#1. A cyclist who stops at red lights and stop signs and who uses lights at night is not necessarily cycling vehicularly.
#2. A cyclist who takes the lane and does vehicular left turns and other examples of destination lane positioning is definitely and without question riding vehicularly.
#1 is a necessary but not sufficient condition of the broad definition of vehicular cycling. #2 is singularly sufficient in the OP definition. A necessary but not sufficient condition is just fluff.
The broad definition of vehicular cycling is overbroad and includes lots of conditional statements. The OP definition contains none. Moreover, the broad definition of vehicular cycling has a self reference, namely, that a cyclist follows vehicular rules of the road. (now, define vehicular) The OP definition is not self referential.
