View Poll Results: Whcih wheels/tires
Zipp 404 clinchers
3
18.75%
Zipp 303 tubulars
0
0%
Kyserium SL's
8
50.00%
Open Pro/Ultegra
4
25.00%
23c
4
25.00%
25c
7
43.75%
Multiple Choice Poll. Voters: 16. You may not vote on this poll
Wheels/ Tires for Webster Roubaix
pan y agua
Quoted: 1442 Post(s)
Liked 711 Times
The Webster Roubaix road race is coming up in a couple of weeks. It's on a 15k circuit with 3k of hardpacked dirt each lap. (although I wonder how sandy that "hardpacked dirt" may be.) Trying to decide on the right wheels and tires. My options are:1) Zipp 404 clinchers (pretty stout wheels, and I can use the PT);
2)Zipp 303 tubulars (added flat resistence of tubulars, but they're brand new and I don't want to trash them.);
3)borrow my wife's Kysersiums (hey what do I care if I trash them, they're not mine.)
4) Pick up a set of Open Pro/ Ultegra 32 spoke wheels ( I wouldn't mind having them for very occassional light touring anyway).
Next is the tire question, if I go with clinchers, 23c or 25c?
Any of you done a road race on dirt roads? or familiar with this course?
So, I'm doing a Roubaix in about a month and I had some similar questions. It's really more about tires.
Are Conti 4000 Gp's okay for a roubaix? I've also got a pair of Hutchinson Comp's.
pan y agua
Liked 711 Times
I think the GP 4000's would be ok. However, if you do flat in the rough section, your race is essentially over. I may get a set of Gatorskins. Looking at reviews they're very flat resistent, and the rolling resistence is not that high.
I'm also thinking 25c might be nice for handling in the dirt section, particularly if it's a bit sandy.
Dirt-riding heretic
Bikes: Lynskey R230/Red, Blue Triad SL/Red, Cannondale Scalpel 3/X9
Quoted: 5 Post(s)
Liked 8 Times
Get some 25c Krylion Carbons and you'll be set.
"Unless he was racing there was no way he could match my speed."
Used to be a climber..
Bikes: 2016 Ridley Fenix SL, 2020 Trek Emonda ALR (rim brake)
Quoted: 7 Post(s)
Bontrager Race Lite Hardcase - pretty bulletproof tires, and they roll pretty well. Not real expensive either, if I remember right, and easy to get on and off wheels.
Eternal Cat3 Rookie
Bikes: 2004 Giant TCR2 Composite & 2006 Fuji Touring
Originally Posted by botto
Pro2Race FTW!
shut up and ride
Bikes: supersix hi-mod,burley duet tandem,woodrup track,cannondale cross,specialized road
i have a set of the pro race2s in 25mm for the tandem. they are much bigger than the 23s and larger than a set of conti 28 and avocet 28s. i would look for a set of those and run the 404s. or maybe you could find a really cheap set of tubulars and look for some big sewups, since i seem to see those wheelsets on ebay all the time
Pro2Race FTW!
Originally Posted by TheKillerPenguin
They should be fine in a roubaix. I ride my pro2's on dirt/mud/gravel pretty often.
Outgunned and outclassed
Hmm, in other words I'm probably okay with the tires I have and don't need to spend any more money. Or is that blasphemy?
My vote woudl be the Vittoria Open Pave tires, 24mm width. They are still fast, but have great grip in some loose stuff. I use the tubular verison for spring races.
Get on a cross bike.... you'll like it ;)
The mods changed this...
I don't use the tubies, but the clinchers are damn near bulletproof. I race them in the rain and have never had an issue.
A good set of 28 or 32 hole hoops with these tires and you won't have a problem.
starting pistol means war
Bikes: Cervelo R3
I have ridden the course twice. One time we did 5 loops at race pace down the dirt section. You can easily run your Zipp404's. I'd run 25's, just 'cause I like them, but the rest of the guys had 23's and had no problems at all. It's not that bad of a road. Good hardpacked with a few ripples at the end.
If you are trying to compare this to true cobbles like in Europe, there is no worry there. The races will bust wide open, but don't worry about equipment. Just run your normal RR setups.
old & slow
How are the enterence and exit to the dirt section? I'd guess that part is gonna be pretty dicey in the pack.
Andy
Andy
Bikes: Cervelo R3
It is a 90 degree right hander onto the dirt, that has some loose stuff, but plenty wide. The road then goes from 2 lanes wide about one lane wide after the first k or so (3k total of dirt). There is one left hand turn halfway down, just after the s/f line. Easily negotiable, but it will make it tougher for those near the back, as the slowing will give the accordian effect for the stragglers and put them even further back. The end of the dirt turns a 90 degree right back onto tarmac and is the roughest section as well. The last 400 meters of dirt has some ripples and a few holes, but nothing to overworry equipment choices over. The edges of the road are mostly gras and I expect people will be bumped out and/or passing on the sides at times. The fun part will be the race to get to the dirt and then positioning as the dirt road narrows to one lane. I expect small groups finishing, so large pack finishes on an 8 foot wide dirt road shouldn't be an issue.
