Another tubeless tire question.
I know I have asked a similar question to this before.------
Has anyone done any combos of tubeless tires.. like a Scorpion in front with the Python in back? They don't have to be the "Hutchinson" brand.
I want a good set up for mountain riding. Colorado. I have an XC bike and the tubeless pythons are great, I just want to know if I should switch over to something different while I'm out in the “Rockeys”.
-Joe
-Joe
I've tried all SORTS of combos in tubeless. I've run Michelin Jet S semi slicks, Michelin XLS in front and rear, the XLS in the rear, and the Front S in the front, the Hutchinson Pythons front and rear, Panaracer Trailblasters front and rear... all sorts of stuff. And the most solid performers I could find were the Michelin XLS in the rear and the Front S in the front. I guarantee if you run those tires you WONT be disappointed reguardless of the terrain. They work in loose sand, deep, sticky, mud, roots, rock gardens, everything.
Dances with Rocks
I've tried a few myself, but the Pythons ought to do fine out there. I rode there last summer on Pythons with no problems. Remember to carry a tube and if you have to patch the tire, scrape the area to be patched very well or the patch won't stick.
If everything seems under control, you're just not going fast enough...
To become a registered member of BikeForums Click Here
Yeah, I don't know what it is with me and the Pythons but I've had some terrible luck. I have patched the rear (which is now trash as a result of a ripped sidewall) tire 3 times and just had to patch the front today. The rear tire (Python tube) I was borrowing for the ride today also ended up with a sidewall slit. Luckily it was at the end of the 23 mile Berryman ride.
If I wouldn’t keep flatting these tires would have been great.. they are fast and hold up awesome for the races but when it comes to just hitting the trails, there they go.
"Check out these beasts!"
Oh my gosh! What are those called? - THE KILLER SNAIL They have to be some slow rolling tires. I bet they cut up the trail real bad.. I take it you have use those before...
Center of the Universe
Bikes: Bianchi San Remo, Norvara Intrepid MTB , Softride Solo 700
I have a tubeless question I have been trying to find street slick tubless for my MTB so I can use it occasionally for commutinh I haven't been able to find any as of yet does anyoner make them?
Matthew 6
Matthew 6
I haven't seen any tubeless street tires in production yet. But when they're made, I imagine they'll be the envy of roadies everywhere
Matthew 6
Matthew 6
#GoatRidesBikes.com
The best all around tubless I've run out here has been the Python...on an NRS-1. And I'm not easy on my stuff either! I cracked an NRS frame...
GoatRidesBikes.com
GoatRidesBikes.com
Originally posted by ngateguy
Yeah, I'm a roadie that swings both ways
Shhhh!! Don't want them to overhear
Well, these are the tires I picked up.. Pricepoint.com -$44.98 for both!
And I couldn't forget these guys.. sad though, there is a backorder on them for over 60 days!!! So if all else fails I will have them waiting for me when I get home. Great price on them at Supergo.com – 27.95 for Hutchinson-Python-UST
Thx to those of you who helped me out on different sites to shop from around the net I believe that I got some good deals... I don't think I could have done the same at the LBS' around here. But don't worry, I still haven't forgotten them.
Around here the equivalent tires run 60 dollars APIECE! I'm all for supporting the LBS, but not when I have to pay twice as much for the same thing!
Yeah, that was a feeble attempt at throwing a hook out to the LBS for them to lower their prices!!!!
I don't feel guilty in the least for trying to make my money go the farthest. Going to the LBS for small things that I need right away is about the only time I go there. Sometimes they act ****ty to you if you bring in stuff you've bought online.. just one more reason for me to maintenance my own bike.
