Disc brake rotor size
This question is always in my head and I cannot find a firm conclusion to it.
If I move a disc brake caliper from front to rear or vice versa, how do I adjust rotor size?
What I have tried to put a rear caliper design for 160mm rotor size and put it to the front. It ended up fitting a rotor of 185mm on front.
With calipers like Avid, I can change the adapter to fit it easily. But some calipers like Magura or Hope, you cannot esp if you want to go from large to small.
Has anyone tried similar things and have an answer to this?
I am thinking of putting a caliper design for 8" rotor (205mm) on front to the rear of a bike.
Thanks
Thanks
Bikes: Intense SS, Old spesh P series, ski/snow bike, fixie conversion
There is no such thing as a caliper specifically designed for 6"/7"/8" rotors. Nor is there such thing as a caliper specifically designed for the front or rear.
All calipers use brake adapters that will allow you to run your caliper either front/ rear or 6"/7"/8" rotors depending on which brake adapter you use.
edit: Nevermind. I think I might be a little ********.
This caliper is design to fit on the front with a 203mm rotor. IF I put a 180 rotor on it, it will not work. The pad will not touch the rotor as the caliper will be extended out and the rotor just spin in the inner circle.
If I put a bigger rotor, yes I can put an adapter to make it work. That just extend the caliper but what about the other way?
Haha wow I just got P3WN3D, I completely forgot about older hope brakes (they no longer use that design).
So your answer is no. You can not run anything smaller than an 8" rotor on the hope caliper posted above.
I have Hope Mono Mini (the new hopes) and its the same thing. They do not just adapter either. I also have Magura Marta/ Marta SL/ Louise FR. They are new brakes but they again do not use adapters like Avid.
I have Avid BB7 and Juicy 7 on some of my other bikes and those I can swap adapter and make them fit front or rear, and what ever rotor size that Avid design for.
So Freeridin', my main question of the post was if I put that Hope caliper (the one i post a link to) to the REAR of the bike, what rotor size should I use? Yes I have to get the correct size lever or just left side and rear and get a longer brake line and bleed the system. But my main concern is what rotor size will I have to use with the front design caliper to the rear...
I put a rear design for 160mm rotor caliper to front and ended up with 185mm rotor to fit it. So if its 203mm front design, should I just put 175 rotor (if there is such thing)?
There has to be some relation.
What I have heard before is ...
Front caliper mount to rear - use a smaller rotor
Rear caliper mount to front - use a bigger rotor
By using smaller/bigger rotor, I mean use a large diameter rotor then what the caliper was orginial design for at its end (i.e. 180mm rear caliper on front, use 203mm on front)
Originally Posted by achc
I have Hope Mono Mini (the new hopes) and its the same thing. They do not just adaptor either. I also have Magura Marta/ Marta SL/ Louise FR. They are new brakes but they again do not just adatpors.
Lever=$90
Line=$30
Rotor=$40
Total=$160
Hayes makes a 178mm and Shimano makes a 170mm, but I have never seen a 175.
https://www.hopegb.com/voir_hbm_image...deimage_1.html
These are just adaptor to increase rotor size, and change mounting style like IS to POST. They are still not making it like Avid where ALL calipers are the same as long as its the same model and you just snap a bracket on it.
To answer my own question which I THINK you appear to be wrong, yes I found out I can run rotors smaller then 8" on the caliper posted above. I just have to mount it at the rear instead of front.
What I have also done last night was put a Avid BB7 caliper with front 160mm adapter onto the rear of a bike and also want to put 160mm. I don't have the rear 160mm adapter in hand so I just used the front. The result was that I had to use a VERY long bolt and put about half an inch of spacers on them.
Proof that when you put front caliper to rear, decrease rotor size
rear caliper to standard front fork, increase rotor size.
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
Why not just run 8" on the rear? Problem solved.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
- I do not have a 8" rotor
- front brake is suppose to be stronger then rear unless you ride backward
- unless you have a FR/DH frame, chances are you cannot fit 8" rotor on your frame
- I ride XC and have 7" on front
- 8" is heavy
but the most important***
when you mount a front caliper to the rear, you will need to reduce your rotor size to mount it unless you are like me. Put a huge spacer and use long bolt to increase rotor size.
Parts Guy
Bikes: several
Since this won't work for you though, I'm thinking it might be time for a different caliper or rear brake assembly to fit your frame and needs, rather than trying to cobble it together.
I think it's either that or your long bolts and washers for spacers.
Actually, I just check the 07 Hope series.
