Go Back  Bike Forums > Bike Forums > BMX
lightest frame
BMX Dirt, vert, flatland or street? Drop in the BMX forum to talk to other 20" riders around the world. What is the best BMX bicycle for you? Learn all about it here.
lightest frame
Old 05-25-03 | 03:50 PM
20 Anniversary
lightest frame
just wanderin if anyone actually knew what the lightest frame was? i have no idea but i know they do make them around 5-6lbs.
nickpark is offline
Reply
Old 05-26-03 | 08:43 AM
20 Anniversary
Standard Bullitt, Kink Cielencki, DBI Patriot are your best bet, but if you are looking for something lighter than that go to https://thickbikes.com/ where they build you a custom frame out of any material that you would like.
athlon822 is offline
Reply
Old 05-26-03 | 01:18 PM
20 Anniversary
where can i get a dbi patriot. and does dbi have a web site? thanks nick
nickpark is offline
Reply
Old 05-26-03 | 07:53 PM
20 Anniversary
DBI patriot can be found on www.danscomp.com Dirt bros website is https://www.dirtbrosusa.com/home.html
They go for around 260.
Reply
Old 05-27-03 | 09:27 AM
20 Anniversary
thanks
nickpark is offline
Reply
Old 05-27-03 | 04:24 PM
20 Anniversary
if u want light get aluminum
Flying Demon is offline
Reply
Old 06-16-03 | 11:09 AM
20 Anniversary
... s&m stricker is really light and it has a euro bb
Roy Mitchell is offline
Reply
Old 06-23-05 | 08:34 PM
Bikes: s&m laf with odyssey dirt forks and other nice things
s&m laf
S&ML.A.F.rider is offline
Reply
Old 06-23-05 | 10:09 PM
FuzzyRyder's Avatar
Live To Ride Ride To Live
Bikes: Fit flow
Don't get aluminum unless you are a racer, aluminum is not made for anything other that racing, the new S&M L.A.F (light as fu*k) frame is if not the lightest, one of the lightest frames on the market, its realy nice and weights in a 5 lbs. alot of good features to, like integrated head tube and the chain stay tubes are welded lower on the bb shell to accomodate a chainstay mounted brake and still run a small gearing
BMX For Life
FuzzyRyder is offline
Reply
Old 06-23-05 | 10:58 PM
Bikes: standard sta-r ox mark4
Originally Posted by S&ML.A.F.rider
s&m laf
you suck
queensrider86 is offline
Reply
Old 06-23-05 | 11:02 PM
member
Bikes: Solid AA
Originally Posted by athlon822
DBI Patriot
Not only is DBI pretty much out of business, but their frames were well known for snapping like string cheese. Also, their frames weren't even all that light.
Actually, it's only available with a Mid BB now; to get a Euro model, you'll have to look around for a '03 or '04 Stricker.
edit: And I just noticed that this is two years old. Good job, f*cktard.
CMcMahon is offline
Reply
Old 06-23-05 | 11:07 PM
Industry still makes wheels and cranks. they probably suck
Reply
member
Bikes: Solid AA
Considering that they're all knock-off parts: yes, yes they do suck. Vic Murphy may be a helluva rider, but he's a shady businessman.
CMcMahon is offline
Reply
Old 06-23-05 | 11:14 PM
industry makes these rims with these "lightening holes" in them. ******** if you ask me.
Reply
Old 06-24-05 | 01:34 PM
BMXTRIX's Avatar
20 Anniversary
this Post Is Over Two Years Old...
Why Are People Responding!!!????!!!????
BMXTRIX is offline
Reply
Old 06-24-05 | 02:21 PM
So, nickpark...You must have come to some kind of a solution by now.
jbonus is offline
Reply
Old 06-24-05 | 03:54 PM
member
Bikes: Solid AA
He hasn't posted since June 2003, so I highly doubt that you'll get a response to that from him.
CMcMahon is offline
Reply
Old 06-25-05 | 04:39 AM
Brian's Avatar
Bikes: 8 bikes - one for each day of the week!
If anyone's truly interested, I can get you a custom BMX frame that would probably weigh 3lbs or less. But none of you race, so never mind.
Brian is offline
Reply
Old 06-25-05 | 10:44 AM
BMXTRIX's Avatar
20 Anniversary
I ride flatland - I'll take it.
BMXTRIX is offline
Reply
Old 06-25-05 | 04:32 PM
Brian's Avatar
It will be the most expensive 10 minutes you've ever spent on a bike. If the same OS tubing that's used on my tandem was used, the front triangle would be plenty strong. But I don't see how they can make the back end strong enough to take much abuse. Too bad, because I'd really like to get myself a custom Ti BMX frame.
Brian is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
