Too much flexing in Bontrager Race Lite rear wheel.
Despite all my rage, I am
Bikes: LeMond Zurich, Colnago C-50
I've got an '06 LeMond Zurich (carbon/steel) with 3,500 miles on it. My problem is my rear wheel. From the factory, it needed major truing, so I paid to have it rebuilt by hand. (LBS said that wasn't covered under warranty.) Now the wheel has too much flex - I can easily move the rim about 1/2 cm each way by hand. The LBS tightened the spokes down for me, but that fixed it for about 500 miles, now the problem is appearing again.
I'm 6 feet tall, 180 pounds. The LBS says this isn't unusual for "high milage" wheels, but I don't consider 3,500 miles "high." Any suggestions?
Thanks,
Thanks,
Young and unconcerned
Bikes: Yeah, I got a few.
You mean the rim is floppy? Or is the hub sliding back and forth on the axle?? (that would be a cups n' cones problem)
(Grouchy)
5mm isn't what i would consider an abnormal amount of deflection in a wheel, especially one with a lower spoke count like the bontrager race lites. unless it's totally floppy and you have loose spokes. i can easily move my 32hole 105/open pro 5mm in either direction by hand and i know that wheel is tensioned properly.
wheels aren't supposed to be completely rigid, if they were, your rim would fail the first time you hit a pot hole, or stood up on the pedals to sprint. if you want something with less flex, maybe try a ksyrium SL, but you'll probably be able to do the same thing.
by having the LBS over-tension the wheels for you to eliminate all deflection, it may have damaged the rim, and the reason you're experiencing the problem again might be that the spoke nipples are starting to pull through the rim.
if the spokes are just coming loose, it's possible that the LBS did not use spoke prep when they rebuilt the wheel for you. if this is the case, they should rebuild the wheel either gratis, or at a reduced rate. IMO, they should not have charged you for the initial rebuild, it is pretty easy to get a labor credit, or even a warranty replacement from trek for things like that.
As far as loose spokes, I can't detect any. (When I had it rebuilt the first time, some spokes were loosed enough to be removed by hand.)
Another thing the LBS mentioned was that "steel spokes tend to flex with age, so this is normal." Which would mean these wheels have a useful life of about 2K miles (since the rebuild.) Any thoughts on that?
You need a new bike
While a wheel with 3500 miles might need to be trued and tensioned, a quality wheel should last much longer than 2000 miles.
CERVEL-LIZED!
Your LBS = Likes Bull Sh@* :-) :-) in my honest opinion only...
this guys pulling a dough on you, next he would say is buy a new set from him. " Looks like its time for you to upgrade to Krysiums now eh?!....hey by the way, I have a set on special...."
I suggest finding a new LBS that = Lends Better Service :-) Cheers!
Making a kilometer blurry
That's just not a stiff wheel, so it's going to do that. You should get the tension checked by a shop that services Bontragers. They're supposed to have really high tension according to the marketing literature. I've tightened a loose spoke for a freind, and his wheel didn't seem very high tension to me, but whatever.
FWIW, I have my 36h Deep-V in my office right now, and I can get that to move 3mm without pushing very hard. It's probably one of the stiffest solo rear road wheels on the forums (36h, 3x, 110kgf drive side, built by me).
Originally Posted by DannoXYZ
Sounds like loose bearings...
Gear Head
Bikes: 07' Colnago CLX, 04' Allez,03' KHS, 79' super leTour304
That is bunk ... your wheel is still under warranty ...... per the 1st reply try a different LBS.
Check out Damon Rinard's Wheel Stiffness test. You're looking at 1-3mm lateral flex on most wheels. If you really want laterally stiff wheels (which doesn't make sense since the load is radial anyway) you can build your own. Get heavy-duty 500gm+ 36-hole box-section rims; touring versions work well. Use large-flange hubs and lace them radially with heads-in orientation. From their test data, you'll end up with a wheel having less than 1mm deflection. It won't make you any faster than you are now though...
UPDATE - I took it to another LBS, and the hub's shot. It wasn't wheel flex at all - a few of you that mentioned the bearings were on the right track.
Anyway, this LBS is more than happy to request a replacement hub from Botrager, and will rebuild the wheel for me for a good price.
Thanks for all your suggestions,
Zurich / Bontrager
I bought the same bike last year with same wheelset. Every ride I had to retrue wheels. Those low spoke count wheels aren't made for bigger riders such as us. I am 6' 200ish pounds. I built up a set of wheels myself (mechanic) Ultegra hubs/DT Swiss RR 1.1 32 hole rims with DT Swiss spokes and brass nipples. Yes wheels are a tad heavy but haven't needed truing at all in 3000+ miles. And my bike rides and brakes far far better with this wheelset than the Bontragers.
Nothing beats a set of handbuilt wheels!!!! IMO
I'm going to look into getting at least a stronger rear wheel later in the year.
Bikes: 2006 LeMond Croix de Fer, 2005 Kona Dew Deluxe
I went through some factory wheels like that. I brought them in for numerous truings, broken spokes and finally paid the LBS to build me a set by hand. The new set only needed a minor truing about 1 month after they were built. Since then I've put 2500+ miles on them without issue.
pedal head
