changing sprockets on shimano cassette
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times
Just how freely can I change sprockets on an Ultegra 10-speed cassette?
I have a 11-23 I'd like to
toss out the 11 and 12
get a 12 that goes in position 1
add a 25 on top
Shimano makes this configuration, but rather than buy it, can I just add those two sprockets?
Or
make a 13-25 (again, Shimano makes this configuration) buy getting a 13- tooth 1st position, adding in an 18 and adding a 25 on top?
I guess I'm asking, do all the sprockets come apart, or are some stuck together. If they are stuck together, how can I find which ones are? Is there a set of rules somewhere?
add a 25 on top
Or
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
add a 25 on top
add a 25 on top
Unfortunately, it won't, 'cause the bottom sprocket needs to have a recess to fit over the hub.
This approach worked great with 7-, 8- & 9-speed systems, but not with 10-speed.
Generally with Ultegra the 3 biggest sprockets are on a spider unit. Other ones are sometimes rivetted in pairs, but can often be separated. The smaller ones are always separate.
Sheldon "Custom Cassettes" Brown
Quoted: 121 Post(s)
Liked 38 Times
Originally Posted by Sheldon Brown
Actually, the 25 would have to go on the bottom! ;-)
And, just for educational purposes, are you saying that my 23 tooth sprocket has a recess and is different than a 23 tooth that's justy inside a 26 tooth?
Quoted: 121 Post(s)
Liked 38 Times
Whoops. I think I found some info at
https://cycle.shimano-eu.com/media/te...9830608752.pdf
that helps me understand all this weirdness...
