Thumb shifter for 9-speed?
Old 03-30-07 | 02:22 PM
To ride is to live.
Bikes: 2005 LeMond Sarthe, 1992 Bridgestone MB-4
Hello there,
Will an old seven-speed thumb shifter set in friction mode work for a new 9-speed cassette?
Thanks!
-Dustin
scrambledwonder is offline
Reply
Old 03-30-07 | 02:24 PM
Sheldon Brown's Avatar
Gone, but not forgotten
Sheldon Brown Memorial - Titanium
20 Anniversary
Bikes: See: https://sheldonbrown.org/bicycles
Originally Posted by scrambledwonder
Hello there,
Yes, but the sprockets are so close together that you may find the shifting a bit finicky.
Hyperglide is generally a bit dodgy with friction shifting anyway, because it doesn't give audible/tactile warning when the derailer isn't quite lined up with the sprocket.
Sheldon "Friction? No Thanks!" Brown
Sheldon Brown is offline
Reply
Old 03-30-07 | 02:26 PM
No one carries the DogBoy
20 Anniversary
Bikes: Roubaix Expert Di2, Jamis Renegade, Surly Disc Trucker, Cervelo P2, CoMotion Tandem
You could get some bar end shifters and paul thumbies and have some 9-sp thumb shifters, but that's not a cheap solution.
DogBoy is offline
Reply
Old 03-30-07 | 02:37 PM
To ride is to live.
Thanks Sheldon!
So basically I'd have to go with bar-end shifters converted to work with Paul Thumbies?
Hmm. . . A bit pricey, but perhaps.
I'll probably just pick up a pair of shimano below-the-bar shifters (as we used to call them right when they came out).
Thanks again,
Dustin
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
