1/8" vrs 3/32" chains and freewheels
FalconLvr
Bikes: 62 Falcon, 58 Raleigh Lenton Gran Prix, 74 Raleigh Pro, 75 Raleigh Int, 75 Raleigh Comp, 76 Colnago Super, 75 Crescent, 80 Peugeot PX10, plus others too numerous to mention!
Quoted: 51 Post(s)
Liked 112 Times
OK, here is one I am ignorant on and would like some help from the knowledge guru's. What is the difference between 1/8" chain/sprocket setups a and 3/32"? I presume one is narrower than the other, does that mean they can not be mixed? Can you mix one way and not the other? I am currently looking at a freewheel that is marked as for 1/8", which is why the questions. Thanks for any enlightenment you guys can supply!
Quoted: 3015 Post(s)
Liked 3,793 Times
A 3/32" chain cannot be run on 1/8" freewheel or rings. A 1/8" chain will work on a 3/32" freewheel and rings, but it will be sloppy and wear the gears quicker. I would recommend matching things correctly. 3/32" is generally for the road and 1/8" is genearlly used for track (and bmx).
surly old man
Bikes: IRO Mark V, Karate Monkey half fat, Trek 620 IGH, Cannondale 26/24 MTB, Amp Research B3, and more.
Quoted: 46 Post(s)
Liked 42 Times
Hmmm. I have several bikes with 1/8 rear cogs and 1/8 chain, but 3/32 chainring. I have never noticed any sort of slop. I also rather doubt that there is any appreciable difference in wear rate.
Fixed people have been mixing this way for a long time. Really does not seem like an issue at all. I suppose I would not go out of my way to set one up this way. (Why add a heavier chain if it is not needed?) But if you happen to have a mix of parts that you otherwise like, I would not hesitate one bit.
jim
jim
Liked 3,793 Times
Quoted: 3464 Post(s)
Liked 2,829 Times
1/8" freewheels were from a time when common was also a fixed cog waiting on the other side of the hub to be switched to. a 3/32" chain will not work as stated, also, a 1/8" chain on a 3/32" freewheel will not work for the vast majority of freewheels, as the cogs are too close, unless is is a very wide range freewheel where the chain can offset into free space, closer ratios will have interference. Long ago we had a customer who almost made it work except for the 14/16 cogs, he added washers and longer fasteners to the jockey wheel cage too, resourceful, and would have saved the cost of a second (and third correct) chain and time if he came to us first.
Quoted: 3809 Post(s)
Liked 6,684 Times
jim
jim
Neal
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
The only multispeed 1/8" cogsets I have seen were hybrid drive train adaptors for Sturmey Archer 3-speed epicyclic hubs, to give one 9 or 12 speeds. I used those with 1/8" chains and either 1/8" or 3/32" chainrings, which worked fine, as long as I had enough width in the rear derailleur cage. (Old Campagnolo Gran Sports, Cyclos, and Simplex TdFs worked fine.)
Liked 6,684 Times
Neal
surly old man
Quoted: 46 Post(s)
Liked 42 Times
Originally Posted by nlerner
I have found the issue to be in the other direction: running a 3/32 chain with 1/8 cogs. It's too narrow and is bound to cause trouble.
Neal
Neal
ko,
feros ferio
Liked 1,324 Times
I have a four-speed block on my 1961 Raleigh Lenton Grand Prix, and it uses a 1/8" chain. But anything produced after the mid 60s would use a 3/32 chain, I'd imagine.
Neal
Neal
FalconLvr
Quoted: 51 Post(s)
Liked 112 Times
Actually the unit I was looking at acquiring is an old Cyclo 4 sp, which would agree with what nlerner has.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
1/8" chains don't flex as well as 3/32". If you want to run a bunch of gears with a quiet drivetrain and not get flaky shifting, go with 3/32"
