Another MKS Tensioner Issue
While I really like how easy the MKS chain tensioners make tensioning and centering the wheel, I've noticed another "issue". The non-drive side tug is a lot easier to loosen than the drive side. It actually worked itself loose enough during a ride today to make a little rattle. If I am loosening the drive side, it takes considerable effort to spin the tension part off the "washer" that fits around the axle. On the non drive side it is really easy. Also, it seems like the tension part slides off the dropouts a lot easier on the non drive side.
I can't figure out what I'm doing wrong. Does this make sense to anyone else?
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
mine broke after getting dirty in the rain
Bikes: Makino (have the parts; not yet built), EAI Barekuckle, Unknown Japanese fixed conversion, Centurion Dave Scott Ironman road bike (frame), Secret project bike, 2007 Trek Madone 5.2, Cannondale Caad3 mountain bike
Originally Posted by deathhare
Never had a problem.
:jarckass:
Well, i dont have a bike. I just have the MKS tensioners. And yeah..no problems with them so far.
***** i ride 10 times more than your pink bike having ass. Pink ass having bike.
I'd have more time to ride my bike if I wasn't so busy riding your mom.
You can send 'em to me if you don't want 'em.
i bought a pair of mks chain tensioners and i snapped one right off the bat, so i just use one on the drive side. f*ck njs and their lack of ability to stand up to my idiocy.
Remove the off-side tensioner and save it for your second bike. You really don't need two. Only thing it does is help you center the wheel when you lock up and that's the easy part.
Make sure the part of the KHS that slips into your dropouts isn't thicker than the bike frame metal. If you've got a Pista or some other frames, that chunk will prevent the washer from sitting flat against the dropout. You can either bend the axel trying to tighten it, or it'll loosen easily because the washer's not sitting flat. The Surly tensioner doesn't present that problem.
tarck bike.com exile
Bikes: bfssfg iro--black.
yeah, if you're having a problem with non-drive side tensioner, just remove it.
a drive side tensioner alone will be enough for you.
