qr to nutted axle?
qr to nutted axle?
Old 04-06-07, 12:44 PM
Walks with a limp
dijos's Avatar
qr to nutted axle?
how can I do it? should I just unscrew the hollow axle, or just puts nuts on it, and remove the qr things? thanks.
dijos is offline
Old 04-06-07, 12:48 PM
is it long enough?
if so just put nuts on it.
if not get one that is.
dutret is offline
Old 04-06-07, 12:50 PM
hockeyteeth's Avatar
I don't believe a quick release axle would be long enough to use track nuts.
hockeyteeth is offline
Old 04-06-07, 01:07 PM
Spawn of Satan
What kind of hub???
captsven is offline
Old 04-06-07, 01:21 PM
domestique
squeakywheel's Avatar
If these are cup and cone hubs, then buy solid axles to replace the hollow QR ones. They are $10 for nice cromoly steel ones at my LBS. The guy there told me front ones are usually 9mm. Rear ones are usually 10mm. Don't know how much truth is in that. The 9mm ones have worked for me on the front hubs of 2 bikes. I haven't had to do the conversion on a rear wheel yet.
https://aebike.com/page.cfm?PageID=30...ils&sku=HU8257
squeakywheel is offline
Old 04-06-07, 01:32 PM
Fissato Italiano
Aldone's Avatar
Bikes: Fixed Gear & Single Speed Only
nuts are better
Aldone is offline
Old 04-06-07, 02:44 PM
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
there are bolt-on skewers that you can get and use, if you don't feel like replacing yr axle.
queerpunk is offline
Old 04-06-07, 03:07 PM
Walks with a limp
dijos's Avatar
Originally Posted by captsven
What kind of hub???
they're shimano road hubs.
dijos is offline
Old 04-06-07, 07:09 PM
Spawn of Satan
I don't know why or care why you want to put solid axles on road hubs but it is not hard. The front should be 9mm and the rear 10mm as squeaky stated. Getting the correct length is the tricky part. If you know the width of your rear drop outs that helps.
THIS should help you out
captsven is offline
Old 04-06-07, 07:24 PM
Paste Taster
Retem's Avatar
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
if its cup and cone just get a new solid axle and rebuild the hub if its sealed cartridges your stuck
Retem is offline
Old 04-06-07, 07:56 PM
Spawn of Satan
I am pretty sure all ShimaNO hubs are cup and cone
Sorry, axle length is not critical for going to solid axles. The length is critical for going from soild axles to QR axles.
If you want to change the spacing on the hub, you may have to add or remove spacers.
If you can replace bearings in a hub, you can change the axle out.
captsven is offline
Old 04-06-07, 09:10 PM
hunter, gatherer
coelcanth's Avatar
the cheapest way would be to replace only the hollow qr axle with a solid nutted type
the easiest way would be to replace only the qr skewer with a bolt-on hex socket (allen key) skewer
coelcanth is offline
Old 04-06-07, 09:27 PM
Walks with a limp
dijos's Avatar
thanks, everybody. I just want to get rid of the QR-ness, so I have 2 wheels that aren't stolen. Pitlocks or a similar product may be the way to go.
dijos is offline
Old 04-07-07, 12:11 PM
blickblocks's Avatar
What's wrong with the queerness?
https://blicksbags.com/
blickblocks is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
