Creaking Bottom Bracket
Color Blind
Bikes: 1970's Fuji Del Rey
Hey, my bottom bracket, maybe the cranks, are making a creaking noise everytime i put a large amount of pressure on them. is this just my bottom bracket? i converted a 70's fuji road bike to fixed gear. Is it that the road bikes's original bottom bracket is not meant to be under that pressure?
it's probably your a) cranks or b) chainring isn't tightened properly. tighten those and see what happens.
also, https://sheldonbrown.com/creaks.html.
a litte bit fixed
Bikes: 24" wheel, fixed, folding airnimal chameleon
try stripping down the bottom bracket and re-greasing it all, I just had this problem and after following all the suggestions from people it works fine:
https://www.bikeforums.net/singlespeed-fixed-gear/286759-bottom-bracket-clicking.html
Bye Bye
tighten pedals, tighten cranks, tighten chainrings
if no good, then pull BB and reinstall.
worked for me.
worked for me.
So long. Been nice knowing you BF.... to all the friends I've made here and in real life... its been great. But this place needs an enema.
i'd leave the sweet stuff
Bikes: BCA ten speed / 2007 bfssfg group buy IRO
degrease and regrease the bb. it probably needs to be cleaned anyways, you'll have to remove the cranks to do it anyways, you can tighten the chainring once they're off anyways, and it's fun to do.
anyways.
anyways.
