Mounting a Nexus 8 speed twist shifter on drop bars, BUT...
Bikes: 2 cdale Caad7. Scatantte CX/winter bike. SS commuter.
Not using the $54.99 hubbub adapter thingy from Harris Cyclery!!
Any ideas? I will not spend $60.00 just to mount a shifter.
I am using it on a crosscheck with 1 1/8 steerer and a 90mm stem and a 26.0 Salsa Bell Lap bar (how generic!).
Any one have any mageuyver ideas?
Edit: Or be ghetto like Kent, cut the bar in half, put the shifter on, and weld it back together.....
Quoted: 2026 Post(s)
Liked 1,096 Times
I've seen a homemade adapter machined from a cut-off section of a handlebar and an inner piece of tube that fits into the cut-off and into the drops of the bike's h-bar.
Gone, but not forgotten
Bikes: See: https://sheldonbrown.org/bicycles
Quoted: 24 Post(s)
Liked 6 Times
I am using it on a crosscheck with 1 1/8 steerer...
Too bad about the 1 1/8" steerer. Before I got my HubBub doodad I was using a cut down mtb bar end on the 7/8" quill of my stem, on my Raleigh International. I found that I would occasionally bump into it with my knee, so I made this:
https://sheldonbrown.org/raleigh-inte...l-nexus12.html
That used a short threadless stem with a shim to make it fit the quill. Where you have a 1 1/8" threadless setup, if your steerer is tall enough, you could do something like this below your regular stem.
The cross piece is a cut-down 1" (25.4 mm) "pipe type" seatpost. The 1" diameter fits the stem perfectly, and the necked down bit where the saddle clamp is meant to fit is 7/8" (22.2 mm) just what the Nexus shifter is made to fit.
In the end, however, I like the HubBub adaptor much better. The ergonomics are really nice, much better than bar-end derailer shifters, in fact.
It is expensive, because it's made in small batches, in the USA, in a machine shop by a human being, while most of bike parts we see are made in huge numbers by fully-automated robot factories. Nobody's getting rich on these.
Sheldon "HubBub" Brown
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
My initial thought is a bar end like used on mountain bikes. and I would probably mount it near the stem hanging down and slightly back from the bar...
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
Quoted: 24 Post(s)
Liked 6 Times
Originally Posted by zorglub
When I was using a setup like this, my knee would sometimes bump into the shifter on climbs. Also, once I upgraded to the HubBub bar-end adapter, the shifter was easier to reach from my usual riding positions, either on top of the hoods or the corners of the bars.
Sheldon "Tried That" Brown
Bikes: Airnimal Chameleon; Ellis Briggs; Moulton TSR27 Moulton Esprit
Quoted: 3291 Post(s)
Liked 827 Times
Originally Posted by ruppster
Would something like this work? Not nearly as pretty, but much cheaper.
Bikes: Bianchi Brava, Specialized Hardrock
attache to spacer rings?
On a 1 1/8" threadless headset, assuming there is enough height of spacers, you could attach a piece of tubing at a 90deg angle to the spacers. Depending on your orientation, you could TIG weld some 1"Al onto the spacers, or take some CF fabric and cross-wrap it
Aaron
Aaron
I just make a sleeve out of aluminum. A little smaller than the inside diam of the bar and the right size on the other end for the Rohloff. Takes about 20min.
I then bond the piece on the end of the bar with two part epoxy. Then mount the Shifter. Easy, never failed on me in many attempts and much lighter and simpler than the hub-bub which I don't really understand. Is there some reason you would actually want to remove the adaptor?
you can cut down the end of the bar if you wish.
Dave Bohm
Bohemian Bicycles
P.S. I agree with Sheldon, the bar end location is the one I prefer. It really is quite good.
Dave Bohm
Bohemian Bicycles
