How to disassemble Shimano road STI lever?
Portland, OR
Bikes: Cannondale: '94 R400; Lemond Poprad '06; Specialized Epic Marathon '06; Specialized Stumpjumper '89; Redline Proline Pro Cruiser '10
Hey all,
I've done some searching here but didn't turn up any thing useful.
So-- I have a left-side 105 (5510, double) STI lever that's developed some additional play. I want to disassemble it and see if perhaps i can tighten something up.
I see from Shimano's downloadable exploded-view diagram and repair parts list that i will be able to get the lever down to a useful level of disassembly.
I'd like to know if any of you have disassembled road STI levers and what "gotchas" you encountered. Any other advice is welcome.
Oh, and are the two "special tools" really necessary? If you have 'em, where did you get 'em?
Thanks for your help.
Quoted: 1572 Post(s)
Liked 642 Times
Shimano road STI's cannot be rebuilt. It is a well known fact that they are not serviceable Many people have tried and failed.
Quoted: 2026 Post(s)
Liked 1,095 Times
You can remove the lever assembly from the body and soak the whole thing in mineral spirits or similar to flush out crud and grime followed by drying and relubing but that is about all. That will sometimes restore functioning to a sticky or skipping shifter. As to detailed disassembly/reassembly, it's never been reported as successful.
They either work or are replaced. You want to rebuild brifters, you have to go with Campy Ergos.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Forgot it. Save the time and headache and get a new brifter.
Bikes: Custom Custom Custom
Keep using it till it completely fails or you can't stand it anymore.
Then buy Campy cause you can rebuild it.
Portland, OR
Originally Posted by vpiuva
are you a watchmaker?
I DO NOT intend to fully disassemble the lever. Looking at the exploded diagram, the levers are meant-- indeed instructions are given in another tech doc-- to disassemble to a certain extent.
By removing the "lever axle" the lever assembly can be removed from the hinge assembly (called "left hand adapter") which holds the brake cable "hook".
As i rotate the lever outboard (the "wrong" way/opposite from shifting) i can see the lock-nut at the back of the hinge assembly also moves.
It's my hope that i can simply tighten this nut (hopefully without the cursed "special tool") and all will be well again-- until the next time i gently knock the lever against the ground. At which point i will buy some Cane Creek SCR-5 brake levers and bar-end shifters.
Annnywayyyy... nobody here actually perform a similar disassembly? Anyone? Anyone? Bueller?
Bikes: HPL steel track, Marin Muirwoods, 1985 Aluminum Trek 2000(?)
I am going to be attempting the same disassembly this week.
A report will follow...
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
There was a thread within the past week where the guy claimed he got them "almost" all the way back together. Search on "watchmaker".
Btw, are those "instructions ... given in another tech doc" online? Scanable?
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Portland, OR
https://techdocs.shimano.com/techdocs/index.jsp
8speed DinoSORAs
I pulled a Sora STI "brifter" apart once. Big mistake! It took me hours to work out where the little spring went AND figure out a way to hold it in place to get things back together. Fortunately I was successful, but definitely a lesson learned. Never again..
Ed
Ed
Get a bicycle. You will certainly not regret it, if you live.
The Red Lantern
I took apart one that had a broken cable frayed in it, with no other hope of removal, and managed to get it back together and working. It is ZERO fun. The couple of times I have pulled a broken one apart it worked just as good when I finished as when I started. If you have a broken one, take it apart and put it back together just so you can wonder how Shimano can do it and still make a profit.
For the Shimano hater. I have a good sized team I fix bikes for. There are two guys with Campy and the rest of the team(maybe ten regulars) have Shimano. I spend way more time repairing Campy(replacing G springs and cracked retainers) than I do replacing Shimano blades. Not that Campy stuff is bad, but it seems to be more in need of maintenance for guys that crank lots of miles and shift a lot(to maintain cadence/heartrate)
Are you a registered member? Why not? click here to register. Its free, and only takes 27 seconds!
Help out the forums, abide by our community guidelines.
I am in the woods and I have gone crazy.
Bikes: Too many to count
I haven't tried to disassemble an STI lever before, but if human hands can put it together, then human hands can take it apart and put it back together. I'm going to have to say though that it might not be worth the effort.
I have tried to take apart and put back together a Campy brifter. Don't fool yourself. It ain't easy. Just because it's Campy doesn't mean that it is maintenance free. My experience is that while the Shimano STI levers almost never need rebuilding. I have already had to rebuild some Campy levers. Pain in the ass.
The Rabbi
Quoted: 16 Post(s)
I would like to point out that while Campy shifters are rebuildable, the expense/difficulty in doing so makes it nearly impractical, especially if you cannot do the work yourself.
That being said, I've taken apart a lot more Shimano shifters than I've reassembled successfully. I can't say I've ever had one develop noticeable play, however. They generally just start missing shifts, at which point they get flushed with an acetone based cleaner, followed by some high pressure air, followed by some light lubricant (T9) followed by more compressed air, and then they typically work awhile longer.
Portland, OR
Originally Posted by powers2b
Do not atempt this unless you know what you are doing, which obviously you don't or you wouldn't have asked.
LOL. Well, then, how does anybody figure out how to do anything if not for someone just giving it a try and sharing with others?
Liked 642 Times
Elitist Troglodyte
- Will Rogers
- Will Rogers
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
Tim
