Any SS riders here sport coaster brakes?
Accuracy is Speed
Bikes: 2007 Bianchi 928 C2C w/ Ultegra compact
Would coaster brakes be an acceptable compromise that removes the need for any brake levers to maintain the simplicity of the SS bike? Or are coaster brake capable hubs either too el cheapo or too dangerous for this sort of activity?
Instigator at best
Bikes: Motobecane Jury
I just got a coaster brake bike, and it's the ****.
As I understand it, a coaster can fail on a long descent where you ride the brake, so if you live in a hilly area then get a front brake. I live where it's pretty flat, so I roll cable-less. Looks soooooo clean.
Be careful though, you'll get hooked on skidding, and next thing you know you'll be dumpster diving for new tires.
There's a thread here somewhere where a guy named jimv goes in depth, find that.
Zig zag wanderer
Coaster only is perfectly fine for casual use. Such utility/around-town bikes are everywhere in Europe, and people aren't getting killed by the thousand for brakes that failed when the chain snapped. But a brake is a brake, and I wouldn't bother if I were you and the hand brake(s) was working.
Bikes: '07 Pista, '09 Fantom Cross Uno, '8? Miyata, '67 Stingray, '0? Zoo mod trials, Tallbike, Chopper, '73 Schwinn Collegiate, '67 Triumph Chopper, '69 CB350, '58 BSA Spitfire, '73 CB450
I have one and use it from time to time, It isn't a true ss, mine is a 3 speed S/A laced to a 27" rim.
It is fun, but I dont' get tooo crazy on it (no front brake).
Bikes: Sngl Spd's, 70's- 80's vintage, D-tube Folder
Mine have weathered some harsh commuting with
no ill effects at all. If anything I think they are
over-built because the types and shear number
of bikes they go opens them up to a lot more
consumer lawsuits, statistically than other types
of bikes.
I like to run a bigger back tire so it doesnt skid
as easily.
*****es love tarck
Bikes: so many
I put a front brake on my Tandem, but my other coaster bike has no front brake. I'd say if you have any large hills or want to ride fast, use a hand brake. (that's pretty much what I would tell someone on a fixed gear too)
Originally Posted by kemmer
There's really not a huge difference between a breakless fixie (assuming a skilled rider) and a coaster brake only equiped bike. With both setups, the cranks need to be in a specific position before you can start stopping. Also, the rear tire does not provide as much traction for stopping as the front one does.
*****es love tarck
Bikes: so many
Originally Posted by ianjk
I think there is a huge difference, I ride both and the coaster allows you to slow down on hills without the need to skip or skid (I use a front brake, but assuming brakeless). Unless you have tree-trunks for legs and bionic knees, there is a pretty big difference.
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
wifey rocks a coaster and she loves it she is also a buck tweny soakin wet with a rock in her pocket
THIS SPACE FOR RENT
keep in mind that a coaster is inherently different from brakeless fixed because you shift weight backward to use the brake, somewhat counteracting the whole "front wheel braking is better thing." Unless you are riding clipless I guess, in which case the awesinineness of your bike grants you some kind of immortality anyway and you don't need to worry about stopping.
Perineal Pressurized
Millions of third world coasties can't be wrong
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
Listen to me
Negative.
Putting a coaster brake on my bike would just about double the total weight and that little bracket would scratch my unobtainium frame.
Ok, assuming a skilled rider with tree trunks for legs and bionic knees, they are similar. I see your point, but I'm just trying to say that if you wouldn't feel safe on a brakeless fixie, a coaster only bike isn't that much better.
I'd wager a coaster brake failure is much less likely than a brakeless riders inability to control ones motion.
Listen to me
Life moves in cycles
Bikes: Rare Conti-Ciocc road, Ricardo Elite, Eric Hendren fixie conversion, Skid Kid Speedway fixie conversion, antique Royal Star
wish we could combine all these coaster threads into one - there's about three threads running all discussing the same issues. just about to build up a sweet brown Velocity Deep V with a coaster for my 700c frame. Running a front brake too, for nose wheelies if nothing else. Lovin' it.
I've been running a coaster as a messanger everyday for about a year now and i feel more in control of my bike than when it was fixed or when i was on a road bike. but what kind of hub you have can make all the differance. I started with a Shimano and loved it, then went to a Bendix red band, it was ok but the problems that it had were to perticular to go into detail about. i've used older perry and sturmey hubs and when it was really cold it would act like a broken freewheel and you would pedal forwards and the cog would move but it would drive the hub. Thankfully i never really hurt myself but i've defenatly fallen on to the bike and put both feet down to stop going somewhat fast. but the shimano didn't give me any problems untill about 6 months of riding (overhauling about twice a month, should have done it more often) when i replaced the entire innards. then that started to wear out too fast, so now i have an old Sachs and it has been pretty sweet. Also i have welded on a slotted tab to bolt the break arm to because i kept breaking straps. if you cant do this i would recomend doubling up on the strap if you are going to be riding this all the time. But don't forget to skid all the time, it's my favorite thing to do especialy when it's raining.
Accuracy is Speed
Weight of coaster hub vs. front lever brake set
Are coaster hubs that much heavier than non-coaster hubs that a front brake lever set would be the better choice, if weight was the issue? It seems that even though the coaster hub is heavier, it still can't be heavier than a brake lever/caliper combo, can it?
Trying to put together the "lightest" possible SS bike without it being a fixie (I got weak knees)
Palmer
Quoted: 1668 Post(s)
Liked 1,821 Times
2007 Little 500 bike by Schwinn:
https://www.cyclingnews.com/tech.php?...s/03-28/Lil500
Shimano coaster.
TCS
Shimano coaster.
TCS
+1 on using a bigger back wheel. Alternate your neutral position so you brake with both legs. Panic stops can be a little iffy.
Bikes: Mino Denti
noob alert! what is a coaster brake? any links to one? how does it work?
ps- im serious here, Im really asking.
Instigator at best
