Using a 10-spd Campy derailleur on a 9 spd?
little ring
Bikes: 2002 Bianchi Veloce, 1980-something Bianchi Axis Pro, 2003 Cannondale R2000
Quoted: 14 Post(s)
Hey all-
Quick question - is it possible to use a (long cage) 10 speed campy rear derailleur on a 9 speed bike? (Bianchi Veloce triple - want to change from 13-26 to 13-28 but need to swap my current medium cage to a long cage. Looking at some on eBay as I'm on a budget. )
Thanks so much!
-KC
Thanks so much!
-KC
little ring
Quoted: 14 Post(s)
The campy site (among others, I think I actually read it on here ) claimed you need a long cage for anything bigger than a 13-26 with a triple. I have a 30-42-52 on the front.
Oh wait, I think I just answered my original question. https://www.campagnolo.com/qea_search...key=comp&rev=1
(See FAQ #1.)
If I didn't have to switch the derailleur to work with the 13-28, that would make me verrrrry happy.
(See FAQ #1.)
Ho-Jahm
Quoted: 5 Post(s)
The numbers campy, shimano, sram ect. give you are usually a few teeth conservative. Just make sure your chain is long enough and I think you'll be fine.
Liked 7 Times
Assuming that the chain lenfth is correct, if you experience slack chain when in a small ring to small cog combination then you do need a long cage derailleur, or stay out of that combination. Don't ride with a slack chain.
Al
Al
Quoted: 2026 Post(s)
Liked 1,096 Times
Originally Posted by Al1943
Assuming that the chain length is correct, if you experience slack chain when in a small ring to small cog combination then you do need a long cage derailleur, or stay out of that combination. Don't ride with a slack chain.
Al
Al
little ring
Quoted: 14 Post(s)
Awesome, thanks! My biggest issue is finding myself constantly switching between the 30 and 42 as I'll run out of steam on the 42-26, then shift to the 30 and find myself cross-chaining when the going gets easier. I like to spin, plus I find a real "granny gear" helps me on the hills.
