SS MTB Wheels
SS MTB Wheels
I've tried some searches, but is there anything that's the equivalent to the greatdealsonbikes Formula/CXP22 track wheelset for SS MTB wheelsets?
Any links to basic/affordable SS MTB wheelsets?
word.
word.
Mexican Food Enthusiast
Bikes: surly Karate Monkey and Cross Check
For a true singlespeed wheelset the best deal is a take off from a redline monocog which sometimes you can find cheap on the bay. The next cheap way is to convert a geared wheelset as I am currently doing with my 29er and it is working better then expected. Bought some XT/Sun wheels and the surly conversion kit and it was 140$ total. Make sure you replace the QR hub axle in the rear with a solid one, which is about 5$ for the part.
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
Really depends how cheap you want to go... a non-disc mountain wheelset can be bought new and converted to SS for less than the cost of the Formula sets. Disc wheelsets are a little more. Do you need a bolt-on axle?
This one and this one are both from the greatdealsonbikes folks and are $110. A BMX cog and PVC spacer would be another $15 or so.
DNPAIMFB
Bikes: Titus El Guapo, Misfit diSSent, Cervelo Soloist Carbon, Wabi Lightning, et al.
+1 on the freehub-having non-disc rear wheel and spacer combo. If you want something a little beefier than PVC, Spot [and others] have aluminum spacer/alignment kits that allow you to easily fine-tune chainline. If you need a tensioner, I would just use an old derailleur [road ders work great]. Surly [?] makes extra-wide splined cogs that fit on modern freehubs and will help prevent the splines from being rounded off the freehub.
I actually just remembered I have an '05 Giant Boulder at home that I can take a bunch of stuff from... yay!
Ok, so, just doing more research.. I should be able to put a SS freewheel + spacers on a Shimano HG hub, right?
Mountain bike **** is weird.
DNPAIMFB
No, you cannot use a thread-on freewheel with a Shimano HG hub. You need a splined cog to go on that freehub body.
Dances With Cars
Bikes: TBL Onyx Pro(ss converted), Pake SS (starting to look kinda pimped)
Shimano compatible singles...a couple spacers, take freewheel off. toss these on, a tensioner and awaaaay you go.
