Pain free? My butt!
Portland Fred
Pain free? My butt!
There are many good reasons to ride a bent, but one of the ones I hear most often that I've never quite understood is why a bent would inherently be more pain free than a DF.
The reason I'm thinking about this right now is that I just returned from a century which coincidentally is the first decent length ride on a new bent I just bought. Despite the fact that the seat was padded, my butt is definitely sore (in fact, much worse than I've ever experienced on a DF). When you get right down to it, most people need somewhere between 4 1/2 and 6 hrs seated and pedaling (i.e. not including breaks) to ride 100 miles. Sit on anything for that long when you're not used to it, and you'll be sore because the pressure points are different for every kind of seat. In my case, the problem will go away by itself as I ride my new bike more, but discomfort seems like a conditioning issue rather than a bike design one.
Besides, regardless of what type of condition you are in and what you ride, you can always work until your legs are so sore that you can hardly walk. Pain is equal opportunity....
Originally Posted by banerjek
...the first decent length ride on a new bent I just bought.
Sit on anything for that long when you're not used to it, and you'll be sore because the pressure points are different for every kind of seat. ...
I'm going to guess that your new bent is an EZ Sport, or something similar with a fairly upright seat, and just possibly a flat, plywood seat base?
Just a guess.
Portland Fred
Originally Posted by Mooo
You make a point.
Just a guess.
Just a guess.
The seat is reasonably ergonomic and it's actually quite comfortable, but I'm particularly bony. For my DF bikes, I'm a huge believer in shorts with gel in them for longer rides -- this has as much to do with damping road vibration as it does comfort.
Right before I went out the door, I suddenly decided that I didn't need my gel shorts in them since the seat has some padding. Had I worn my normal shorts, I probably would have been fine. Live and learn. When I first got my trike, the maiden voyage (except a 3 mile test ride to do some basic adjustments) was a century. That worked out fine.
Let us know how your butt feels tomorrow. I know riding a century on an upright, without considerable acclimation, would make it hard to walk for several days. And I'm not talking about sore muscles.
There is a name for that, recumbutt. I had a Corsa so I am familiar with the riding position and while I never had the problem on the Corsa, I have had it on other bents. Solutions are many, two that always work for me is either a small pad under the small of the back, lower than you mught guess, or more recline. Besides building those new muscles, you got to not be sitting on the ones you are using... sort of
Super Modest
Quoted: 10963 Post(s)
Liked 4,618 Times
Keep the chain tight!
Quoted: 303 Post(s)
Liked 136 Times
Ha, Trsnrtr, I am saddle shopping for the stoker seat on a
friends tandem. I did a century about 6wks ago and it was
a bit annoying, but ok after a few days. Tried another saddle
(vintage Cinelli) and it was horrible, had to abandon the
century at 65mi. Third saddle was ok to 75mi but got more
and more obnoxious til we cut things short at 94mi. (Terry
Gellisimo) Going to bug the local tandem dealer for some
other saddle options.
Re the OP: I had to accomodate to my Rotator Pursuit
seat over a period. There is initially the pressure pain of
sitting more or less in one position constantly and the
gluteal pain of using different muscles. After a few hundred
miles both went away and the bent is FAR FAR more comfortable
than the DF. I did try a Bacchetta Aero once and had significant
butt discomfort at 25mi. I think an angle and position change
would likely have improved matters.
Portland Fred
Recumbent Ninja
You also use different muscles on a bent that must acclimate, so some discomfort is to be expected. When I switched from the lowracer to the P-38, my butt and inner thighs were lit on fire, even though I was already bent acclimated. Plus the angle of some seats need to be fit correctly, just as seats on a df do.
Once you have that down, you can do a century, take a quick break, and go on another one!
cyclopath
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
Liked 6 Times
A bent will be more pain free than a DF because your body weight is being supported over a much greater area and none of your body parts are forced into non-ergonomic positions [ie. looking up on a DF bike].
Given your newness to bents I am not surprised you are a bit sore after a century ride. You need to acclimatize your muscles and give yourself some time to setup the bent correctly.
Your butt could be sore for two different reasons: 1) you are using new muscles there and they are complaining about the lack of conditioning. 2) your seat is too vertical forcing your butt to support too much weight - particularly if it ends up compressing the muscles that are doing some of the work.
Finally I don't think anyone who says bents are pain free is referring to lack of muscle soreness after a big ride. They are talking about the ergonomic discomfort common when riding DFs a long time - butt, neck/shoulders, feet, etc...
I would get some more miles in your legs and adjust your bike a bit before tackling the next big ride.
It's Challenge Seiran SL with a carbon fiber seat. Being a highracer, the seating position is fairly reclined. Here's a shot from the maiden voyage, though I've made substantial adjustments since the pic was taken.
I rode an HP Velo Speedmachine once. Didn't care for the saddle, although some people love 'em.
Vive la differance, oui?
Approaching Nirvana
Bikes: Catrike Expedition
"The difference between genius and stupidity is that genius has its limits."
-- Albert Einstein
-- Albert Einstein
