The Unlimited Budget, perfect folder for you thread
Old 05-17-07 | 06:18 PM
14R's Avatar
14R
Bromptonaut
Bikes: 1994 Diamond Back Racing Prevail ti; Miyata 914, Miyata 1000, 2017 Van Nicholas Chinook
If you could have all the bike manufacturers seating around a long table with bike designers and everything else to design a perfect folder for you, what would it be?
Here is mine:
1- 16" wheels, similar to a Brompton, without the little chain tensioner (more like the Tikit setup);
2- Rohloff 14 gears;
3-fit into internationally accepted luggage with just minor adjustments (removing the seat, front wheel, etc...)
4-Performance oriented. Capable of doing a century without being considered a hero;
5- once folded, easy to transport.
I believe the closest thing to this is currently the Brompton, isn't it?
14R is offline
Reply
Old 05-17-07 | 07:19 PM
Well, since the sky's the limit:
1. Frame design that allows for variable wheel sizes (as wide a range as possible) so you can swap in smaller/larger wheels to achieve the desired folded size/weight for the day. Of course, when you swap in the 26" wheels it should ride as well as a 26" wheeled bike, otherwise what's the point?
2. More rugged construction so you don't have to use a suitcase for airline travel, just a bag. Most 20" folders meet airline size requirements when folded, the problem is that you need to put them in a case to protect them. Make the bikes from titanium or unobtanium or something so that the folded bike is as strong as any suitcase. Obviously this would need to include more than just the frame, as current designs have many other fragile parts.
3. Make the bikes much lighter. I realize that UCI weight limits discourage R&D from pushing component weights lower than what they are, but this is my damn wish list. They put a man on the moon; Don't tell me they can't make a 5 pound Brompton.
Give me all of the above without compromising much in terms of ride quality, gearing, etc (basically don't make it a worse bike than currently available folders) and I'd pay the price of a new car.
makeinu is offline
Reply
Old 05-17-07 | 07:27 PM
Rincewind8's Avatar
Radfahrer
20 Anniversary
I think riding a century on a 16" wheeled bike will always make you a hero from most people's point of view...
TH 1.81 (133kg*62)
Rincewind8 is offline
Reply
Old 05-17-07 | 09:51 PM
1. 16" wheels
2. A Moulton F-type frame that actually folds with accompanying rear and front suspension.
3. 23mm Race tyres.
4. Drop bars
5. Ti Frame
6. One of those awesome Brompton front bag mounts!
juan162 is offline
Reply
Old 05-18-07 | 09:08 AM
Polaris43's Avatar
Here is mine:
Add:
6- Capable of touring with a reasonable (for this size bike) load
7- a FD so you can have a granny gear for big hills (is this possible / desireable with a Rolhoff?)
8- rolls when folded and stays folded (some type of lock / latch)
9- FENDERS
Polaris43 is offline
Reply
Old 05-18-07 | 10:05 AM
Rincewind8's Avatar
Radfahrer
20 Anniversary
Possible - yes, desireable - no, necessary - no
The Rohloff has a gear range of 526% compared to an average 27-speed MTB gear range of 519%. So the granny gear is built into the Speedhub.
https://www.rohloff.de/en/products/sp...son/index.html
TH 1.81 (133kg*62)
Reply
Old 05-18-07 | 11:14 AM
14R's Avatar
14R
Bromptonaut
Right now, from the well known folding bike universe, which bikes accept a Rohloff without any major Mods?
14R is offline
Reply
Old 05-18-07 | 11:17 AM
Hauja
Bikes: not as many but still too many
A Downtube VIII NS with a spare wheel for fixie/ss use or a mini set up the same way.Or alternatively a hon Solo with a spare 8 speed wheel(Internal Hub).
James H Haury is offline
Reply
Old 05-18-07 | 11:18 AM
Hauja
Maybe,
Bikes which might accept a 14 ratio Rohloff hub,hmmm.Possibly a downtube VIII or a hon solo or another Dt model with an internal hub.
Reply
Old 05-18-07 | 11:50 AM
caotropheus's Avatar
Titanium R20 type frame, full centaur groupset, carbon fork, 451 wheels, Thomson seatpost, integrated handlebar - stem, MKS detachable pedals, etc, etc.
caotropheus is offline
Reply
Old 05-18-07 | 01:55 PM
DaFriMon's Avatar
Member, Schmember
Bikes: Bike Friday Crusoe and Pocket Tourist. Dahon Curve D3 and Speed P8. Raleigh Twenty. Bianchi Eros. Highly modified Mongoose Dynametric (hybrid)
There are at least two reasons why I have more than one folder. One is self-indulgence, the other is that I haven't found a single model that is perfect for everything I want to do on a bike. There are times when my Curve is just right, others when the only folder I'd use is my BF Crusoe. For one folder to be perfect, I'd have to be equally comfortable using it to go grocery shopping, or light touring, or riding in a century.
If I do imagine a single perfect folder, it's closer to a Bike Friday than a Brompton, but with an easier and smaller fold than the classic Bike Friday Pocket models. The tikit could be a step in that direction, although the current model may not be quite there. Road bike geometry, reasonably wide gearing range (say 30-100 gear inches or better). I'm not a gear snob; I'll take an internal gear system if I'm convinced that it will give me adequate performance over a reasonable range, otherwise front and rear derailleurs, or a wide range 9 speed rear derailleur only system. Haven't tried the really high end internal gearing systems, so I can't be more definite than that.
Not too heavy, let's say 24 pounds max, but sturdy enough to carry heavy loads on occasion. If price were truly not a factor, titanium might be a good way to get that, otherwise chromoly.
Unsuspended, except for the possibility of adding a springy saddle and cushy tires. I've found I get along fine without suspension, so it seems like an unnecessary complication.
Fold, small, easy, and quick enough to bring inside almost anywhere. It doesn't have to be absolutely the quickest, smallest, and easiest, just good enough that folding doesn't seem like a hassle. A design that lets it fold reasonably small even with drop bars.
Sufficient clearance and good mounting points for fenders. Easy mounting of front and/or rear carriers. Maybe some quick release system for carriers, so you can take them off without much trouble when they aren't needed.
I could see this working with either of the two 16 inch sizes or the two 20 inch sizes, but I'm thinking 406 might be best. Not a scientific opinion.
DaFriMon is offline
Reply
Old 05-19-07 | 05:06 AM
"A Downtube VIII NS with a spare wheel for fixie/ss"
Harris sells a self branded flip flop hub that has freewheel + fixed on both sides. $40.
I think a belt or shaft drive would be nice for traveling and general use bike.
geo8rge is offline
Reply
Old 05-19-07 | 11:23 AM
Dr Kickstand
Bikes: Montague Hummer 2006
How about a folder can be folded so small, it can be brought as hand luguage on an aircraft.
I think the weight is a big thing also.
DrK
Shaymo is offline
Reply
Old 05-20-07 | 02:09 PM
20 Anniversary
Bikes: Early Cannondale tandem, '99 S&S Frezoni Audax, '65 Moulton Stowaway, '52 Claud Butler, TSR30, Brompton
Birdy
LWaB is offline
Reply
Old 05-20-07 | 02:39 PM
14R's Avatar
14R
Bromptonaut
DrK
That would be really, really nice...
14R is offline
Reply
Old 05-20-07 | 04:21 PM
pm124's Avatar
Car free since 1995
Bikes: M5 Carbon High Racer, Trek Emonda SL6
Yes, Birdys (Birdies?) ship stock with Rolhoff.
But my ideal bike would be as follows:
Birdy monocoque frame. (Yes, you can *comfortably* do a century on 355 wheels. More comfortably than on a touring bike!)
Zipp cranks (650gm, including BB)
SRAM X9 derailleur/shifter/freewheel
Chris King classic hubs and headset
Alex DV16 355 rims or Velocity Aeroheat 349 wheels. (The Birdy can, as a stock bike, accept 349, 355, or 369 Moulton wheels. Does anyone have better rim recommendations?)
Help me with the brakes. The stock Avid brakes?
Seat: Terry Fly or Velo Plush. Don't like seats that mush the soft parts.
How much would it weigh? With 349 wheels and 40gm tubes, probably 7.5Kgs. Lighter and more comfortable than a Bike Friday. Maybe stiffer, too.
There: a folder so small it can be quickly packed in a 29" suitcase, is comfortable on 200 mile tours, can keep up with the roadies, has suspension but not energy absorbing suspension, folds in under 10s, is smaller than any other folder but the Brompton (and those 305 folders), is light enough to carry for long distances, and is small enough to fit under the table in a crowded resturaunt when folded. The cost? Yikes! I would guess over 2 grand even if everything was bought at the lowest possible prices.
If someone could help me get this bike lighter with cost-effective components (e.g., rims, cranks, etc.) please let me know. I just might partially implement this one day when the savings accrue. For instance, I think FSA might make similarly light cranks when paired with a light ISIS BB. Help appreciated!
pm124 is offline
Reply
Old 05-21-07 | 09:30 PM
DrK
That would be the a-bike.....if you think you'll get a bike like that with 16" wheels then you got another thing coming (even a 16" wheeled unicycle is probably too big for a carry on).
makeinu is offline
Reply
Old 05-21-07 | 10:42 PM
I would say...
Something that rode like my Friday Pocket Rocket Pro, but folded something like a Brompton. Extra special bonus: you could buy one for less than a grand.
A real bike that could travel as carry-on luggage would be terrific. But I don't think it can be done. The under $1k Friday/Brompton is as much of a fantasy, but possible.
noahj is offline
Reply
Old 05-21-07 | 11:11 PM
20 Anniversary
Magura is a nice option.
LWaB is offline
Reply
Old 05-22-07 | 12:21 AM
jur
Perhaps carry-on luggage is a thing of the past anyway... unless you can fit your folding bike in a transparent ziplock bag.
jur is offline
Reply
Old 05-22-07 | 04:27 AM
Hauja
One of the people at Gaerlan
One of the people at Gaerlan made a bike that could be brought on as a carry on.It was never marketed because he did not think it had commercial potential.I beleive it had 16 inch wheels and he rode it around NYC .He actually did fly with it .
Reply
Old 05-22-07 | 09:24 AM
It only fit into a carry on legal suitcase without the wheels:
https://www.gaerlan.com/others3/ny/ny.htm
makeinu is offline
Reply
Old 05-23-07 | 07:52 AM
cyclist
Bikes: road bike, mountain bike, touring bike
Even though I do not have a folder I'll say what my dream bike it. Start with a Dahon Smooth hound (full size bike with 20 inch wheels), Make the top tube more sloping, make it fit me with a 120 degree rise stem that is 140 mm long, add the Ritchey Breakaway system and since price is not object, make it carbon lugged with titanium. OR... teach me how to weld and I can settle on steel or if price is still no object, titianium. Teach me how to weld and make carbon tubes and I'm back to the carbon and titanium.
One built up like a speed machine and one made up for touring.
Scott
ncscott is offline
Reply
Old 05-23-07 | 08:09 AM
stevegor's Avatar
Bikes: lots... even a Raleigh twenty !!!
Why hasn't someone come up with the idea of a folding bike that can be folded into the shape of a wheel chair.....think of no hassles on airlines and the sympathy you would get, just don't fold it back into a bike until you're out of sight.
stevegor is offline
Reply
Old 05-23-07 | 08:31 AM
Scooper's Avatar
Decrepit Member
Bikes: Waterford 953 RS-22, several Paramounts
DrK
This award winning design from the seventies would meet both of those requirements. To my knowledge, it's never been built and probably wouldn't be comfortable for rides of more than a few miles, but I think the concept is really intriguing. Brompton and Merc are probably the only current production bikes that come close.
- Stan
my bikes
Science doesn't care what you believe.
Scooper is offline
Reply
