How to clean Open Pro rims?
Old 05-18-07, 02:51 PM
Retro-nerd
georgiaboy's Avatar
Bikes: 1991 Serotta Colorado II, 1986 Vitus 979, 1971 Juene Classic, 2008 Surly Crosscheck, 1956 Riva Sport
Quoted: 30 Post(s)
Liked 57 Times in 39 Posts
My Open Pro rims get dirty from commuting in bad weather and braking, and road dirt. I use degreaser on them and it really cleans the brake dust off. The problem is the degreaser leaves them dull looking. No polished silver look at all. Should I be using something else beside degreaser or is there another step to finish it off and have the wheels shine, again?
Would you like a dream with that?
georgiaboy is offline
Old 05-18-07, 05:00 PM
Mr. Beanz's Avatar
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Liked 4 Times in 3 Posts
I spray a bit of WD40 onto a rag and wipe my rims down carefully. I avoid nipples,threads and-hook areas. Don't want to dry out any contact points that may result in breakage. I used to use degreasers and simple green stuffs. Had spoke problems. One builder told me wasn't good as it dries out the nipples making it tough to do adjustments down the line.
I wipe down mid sections of spokes, rims and brake surface. Brake surface is a lil squeaky (squeaky clean)for a while but after a mile or two, back to normal.
Mr. Beanz is offline
Old 05-18-07, 05:45 PM
Retro-nerd
georgiaboy's Avatar
Quoted: 30 Post(s)
Thanks, I'll give it a shot.
Old 05-18-07, 06:19 PM
Proxymoron
Bikes: Jamis Coda Sport, Marin Muirwoods
Windex. Seriously.
keytree is offline
Old 05-18-07, 07:00 PM
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
I put wheels in a wheelstand or clamp the whole bike in a workstand and pull a clean shop rag between each pair of spokes. It takes about 2 minutes per wheel.
Retro Grouch is offline
Old 05-18-07, 11:30 PM
Mr. Beanz's Avatar
Doh! I forgot to mention. I use a toothbrush to clean the hub area and spokes where spokes lay against the flange and enter/exit the holes.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
