Best way to install brake levers
Look KG386i
Bikes: 2004 Look KG386i
Is there a trick to ensure both levers are installed at the same level/angle on the handlebars?
The Improbable Bulk
Bikes: Many
Quoted: 5 Post(s)
Liked 7 Times
I hold a level (as a straight edge) on the bottom of the drops. and adjust the brake levers so that the tip of the lever just touches the level...
This only works if you happen to like the way this lines up, but it is one of the traditional methods.
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
Title-Les
alf
i'm kind of a geek but i set one lever exactly where i want it, then tape a piece of cable along the bar so it touches the clamp. i cut it at the end of the handlebar, then move the cable to the other side and tape it to the bar and slide the second lever till the clamp just touches the cable. takes a couple extra minutes, but i end up with them perfectly even.
Quoted: 1572 Post(s)
Liked 643 Times
Originally Posted by the sloth
you could always use a measuring tape to measure from the bottom of the drops up to the bottom of the hoods.
