Chorus triple on symmetric BB?
I just installed a new Phil Wood bottom bracket on my bike (110.5mm, Campy taper). In the process I noticed that the middle chainring of my Campagnolo Veloce triple crank is looking a little worn with what look like some chips in a couple of the teeth. I've been shopping around for replacement chainrings, and I can almost get a new crankset for what a replacement Campy chainring costs. I've run across some clearance deals on brand new square-taper Chorus triple cranksets that are in the same price range and I'm tempted.
The only problem is that Chorus/Record cranks require an asymmetric bottom bracket that is, I think, 2mm longer on the drive side. Has anyone tried running a Chorus triple on a symmetric BB? What about if I adjusted the Phil BB to shift it 2mm to the drive side? Is it just a matter of chainline, or is there something special about the Chorus/Record triple BB that I'm not taking into account?
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Provided the chainline is correct (strictly a function of the drive-side axle length), then the only effect of an a/symmetrical axle is location of the non-drive side crank arm: non-critical.
Just be sure that if the non-drive side axle is shorter, then it's not too short. Otherwise no worries.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Liked 7 Times
If I worried about a couple of chipped teeth I'd have to look for false teeth for my head.
Ride it and quit worrying.
Al
Al
