Need opinion--Vittoria tires
Quoted: 1722 Post(s)
Liked 1,272 Times
I recently saw an article comparing the rolling resistance of various tires. The Vittoria Open Corsa EVO CX Team CSC Limited Edition were highly rated and on sale at Nashbar, so I bought a pair. I've put between 100-150 mi. on them and like them a lot. However, today I noticed a couple of significant nicks in the rear tire. One was definitley through to the tube and the other was deep but not through yet. Just wondering if this is typical of the tire construction. You know, like fast but fragile. Or, is this just bad luck?
Gios
Bikes: Pinarello Rokh, Look 586, Merckx Corsa 01
There's another tyre thread here, GP 4000 s (that's the "s" version) and Michelin Pro Race 2 are getting a thumbs up it seems.
B
Quoted: 1572 Post(s)
Liked 642 Times
To minimize rolling resistance you want a tire that is very flexible. To improve puncture resistance you'd make the tire thicker and maybe add a kevlar belt under the tread, but that's going to increase rolling resistance. Everything has trade-offs.
I used that tire recently and went back to my Gatorskins. Seems that when they flat (and I did that a lot with them) they tend to destroy the tire, making repair almost impossible. I bought three, destroyed one and flatted the other two. All in under 300 miles. Just my experience, but with Mich Pro Race or Gatorskins I rarely, ever get a flat.
feros ferio
Quoted: 1384 Post(s)
Liked 1,294 Times
I just switched the UO-8 to Vittoria Zaffiro 27x1-1/4s after wearing out my circa 1999 Schwinn 27x1-3/8" knobbies (center tread in back, ominous beginnings of sidewall irregularities ("bubbles") in front). So far, so good, but I'll post again with updates. SInce the Peugeot has non-hooked Weinmann aluminum rims, I inflate tires to 80 PSI, instead of their rated maximum pressure of 100 PSI.
Liked 1,272 Times
Well, I continue to pick up nicks and little cuts to the tires. But, boy do they roll nicely. Also, as you might imagine, they are incredibly easy to mount. If I were to go to a more durable tire, any suggestions for a tire that not only rolls well and is more durable but is easy to mount?
Liked 642 Times
Liked 1,272 Times
Originally Posted by Retro Grouch
Bruce. Didn't you mean to say "they are incredibly easy to install"?
feros ferio
Liked 1,294 Times
... Also, as you might imagine, they are incredibly easy to mount. ...
Victorias DO fit nicely,I have had the EVO's Teams,a bit racy. I've used Open Corsas in general. They ride better than other clinchers I've had. As far as durable, yes, quite. Continental and even more-so Specialized are "tuffer". Both handle noticeably different than Vics, turning and feeling supple.
Ti #18 Senior.
Bikes: Serotta Concours
Open Corsa EVO CX did not work for me as a rear tire - too fragile. Pro Race 2s were also too fragile on the roads I ride. But, I can - for some reason - use theEVO CX the front and I really like the ride that gives. I use the more durable GP4000 on the rear and will try the 4000S when it becomes available. YRMV.
Jim
Jim
Hypoxic Member
The CXs are very fast (and fragile too). On group rides on slight
downhills, to maintain a conversation I would have to brake while
talking to someone pedaling. This was not a single observation.
Liked 1,272 Times
