How bad is this?
Your mom
How bad is this?
I recently came into possession of this Nishiki, which I am fixing up as a single speed. The owner had obviously has a little accident with it, of the derailleur-into-the-spokes type.
The derailleur (a Suntour ARX) has apparently lost its lower pulley and is a little bent at the hanger bolt. The cage is straight, though.
The wheel has one bent spoke and a dent in the dork disk. Despite the bent spoke, the wheel is pretty true.
My question is this: can I reuse the rear wheel? If so, do I need to replace the spoke?
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
I think the wheel is okay, though I'd replace the bent spoke. You going to try to salvage the dérailleur?
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Quoted: 114 Post(s)
Liked 118 Times
Yes and yes.
In the current condition of a bent spoke and the wheel being true, I'm pretty sure someone trued the wheel, and in order to compensate for the the bent spoke, had to create uneven tension in the spokes. Ideally, all the spokes on a side of a rear wheel should have equal tension.
Is the wheel dished and round (in addtion to lateral trueness)?
Your mom
I am not planning on salvaging the derailleur. Haven't checked dish and roundness on the wheel; I've only done the rough brake pad test.
Thanks for the help!
Skybird
Bikes: 2006 Trek 1500
Curious how there was just a thread on dork disks over
there ----> https://www.bikeforums.net/bicycle-mechanics/303315-dork-disc-yay-nay.html
