More Campy Confusion - QS and Escape
Ho-Jahm
Quoted: 5 Post(s)
A few more quick campy questions.
From what I understand, pre 2007 campy FD shifters were ratcheted, not stepped like shimano.
My veloce 2007 FD and Shifter are both "QS" models. I don't know if they have the "Escape" feature, what that is or what QS/quick shift does.
Can anyone enlighten me?
The bikes not built yet, but I can click my FD shifter lever arm (one under the brake lever) 6 times, but then the thumb shifter clicks only twice.
What does that mean?
Unique Vintage Steel
Yes your 2007 Veloce utilizes the QS system. Means that there is a shorter throw to shift to the big chain ring on front. There are still multiple notch trim positions on the way up, but going down to the lower chain ring there is only one middle trim position. (Takes two hits of the thumb trigger to drop to the small ring)
The ESCAPE mech means that you can only downshift 1 cog at a time. You can still go up 3 at a time, but only down one at a time. I have this on my Centaur equipped Flyte and don't really mind not being able to go down more than once. The action is so quick I just tap it a couple times and find the gear I need. I am working on building a Chorus equipped bike and will reserve final judgement till then.
Quoted: 2026 Post(s)
Liked 1,096 Times
I exchanged them for '06 Record brifters to get the same "micro adjusting" shifting I have on my '06 Chorus.
Campy's web site is not too helpful about the '07 Chorus and Record front shifters but I think they allow "micro-adjust" shifting in front like the old ones did. Let me know how yours work out.
Interesting info HillRider. As far as I know the front shifter is unchanged for 07 other than the different pull ratio for the QS front derailleur.
Bikes: Custom Custom Custom
07 centaur and below are indexed. 07 chorus and record are the same as they were except with the ratio change for QS
Tim
Liked 1,096 Times
Originally Posted by cs1
Can you put in the Record Ergo gear in a Centaur brifter to make it like last years only with the proper ratio? Used to be the internals on all Campy brifters down to Mirage were basically interchangable. The only real difference were bearings vs bushings.
Tim
Tim
Now, what it will cost is a different matter.
Liked 7 Times
Originally Posted by HillRider
I think so. I recall reading recently that some of Campy's sponsored Pro Tour riders had '07 Centaur internals installed in their earlier Record brifters because they wanted the "Escape" (one at a time upshifts) rear shifting. That implies to me that the internals are interchangable.
I can see no advantage to one at a time downshifts.
