chain in spokes?
chain in spokes?
Old 06-05-07, 11:20 AM
Quoted: 9 Post(s)
Liked 3 Times in 3 Posts
chain in spokes?
On my ride yesterday in pouring rain we were coming up on a stop sign and I downshifted ... I was in the big ring and didn't realize I was getting crosschained. This made the chain drop off the big ring and it dropped all the way off to the inside. I've had this happen a couple of times before ... no biggie just push the fd back up and it gets back on (TruVatuv Rolleur/campy veloce fd) But this time I guess it pulled the chain off the cassette and into the spokes too. I heard the non normal grinding and got on the brakes just before the rear wheel locked up. Skidded/fishtailed to a stop keeping everything upright. Chain was wrapped pretty tight around spokes, I was able to free it back up with some effort and ride back home. Noticed my up shifts were slightly off. (campy centaur rd)
Got home and checked it out ... scratches on a few spokes/ one spoke definate bend where is goes in the hub (Campy Zonda's) No noticable rd damage, some scratches on a few chain links but no binding.
I've done spoke replacements before, but do you think I should take it in and have rd alignment checked too? I would think all the limit screws are set OK as drivetrain has 3500 on it. Only time I get the chain drop issue is getting crosschained with some load on it? Suggestions?
Paniolo is offline
Old 06-05-07, 11:27 AM
barba's Avatar
I would have the rear wheel checked carefully and have someone set of the rear limit screws properly. The fact that this has happened before suggest something is amiss.
barba is offline
Old 06-05-07, 11:30 AM
Call me The Breeze
I_bRAD's Avatar
Bikes: 2004 Litespeed Siena, 1996 Litespeed Obed, 1992 Miele (unknown model), 1982 Meile Uno LS.
Liked 7 Times in 4 Posts
Originally Posted by Paniolo
But this time I guess it pulled the chain off the cassette and into the spokes too...
I don't think these two statements belong together.
Also, stop using cross combinations.
I_bRAD is offline
Curmudgeon
Wil Davis's Avatar
Bikes: (see https://wildavis.smugmug.com/Bikes) Bianchi Veloce (2005), Nishiki Cascade (1992), Schwinn Super Sport (1983)
Liked 4 Times in 4 Posts
…Suggestions?
Dork Disk?
- Wil
Wil Davis is offline
Old 06-05-07, 12:10 PM
Quoted: 9 Post(s)
Yeah, I try not to get cross chained ... but sometimes I just hit the downshift and and don't notice the 23 is the next cog.
It's never come off the rear cassette before ... just the front big ring. And even then it doesn't happen on a fd shift, just when I get cross chained big/big. Does that indicate a limit screw issue?
Paniolo is offline
Old 06-05-07, 02:38 PM
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,269 Times in 876 Posts
If the chain goes into the spokes, IT IS a limit screw issue. Screw the L limit screw ina 1/2 turn or so.
Bill Kapaun is online now
Old 06-05-07, 04:05 PM
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
I'd strongly advise pulling your cassette to check the spokes. I'd be surprised if all of the outside spokes on your drive side hub flange aren't buggered up.
Retro Grouch is offline
Old 06-05-07, 04:58 PM
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
Quoted: 486 Post(s)
Liked 11 Times in 11 Posts
Sorry, not true and not the proper solution. It is clear from the explanation that the problem in the rear was initiated by the front unshipping. Makes perfect sense, as the pulley assembly would have whiplashed due to the absence of chain tension. Absolutely have the derailleur hanger alignment checked, replace any drive side spoke showing damage. Also after the hanger alignment is correct rotate the derailleur on the main pivot to see if the angle of the pulley assembly changes (should stay close to parallel to the wheel). Of course the front and rear derailleur adjustment should be checked as well.
As for the front unshipping when going to cross chain that may be hard to avoid depending on many factors alone or in combination. Some combinations of short chainstays and 9/10 cog cassettes, especially if the alignment between chainwheels and cogs is a bit off (cogs too far inboard) can be very problematic. It's admittedly hard to remember where you are in gearing with STI shifting - in the old days shift lever position would tell you.
cny-bikeman is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
