how often do you use your rear brakes?
Accuracy is Speed
Bikes: 2007 Bianchi 928 C2C w/ Ultegra compact
I just noticed that 80% of my braking and modulation are with my front brake and I only use my rear brake if my left hand is busy off the bar, or for quick stops then both brakes are clamped.
How often do you use your rear brakes if at all?
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Bikes: S-Works Tarmac
Quoted: 182 Post(s)
Same here. Front approx. 80% of my braking effort, if not a bit more. Rear braking just for balance.
I ride my bike
I use both brakes 95% of the time. Of course, the front gets most of the pull.. I use the rear just enough to keep it from locking up. Practice extreme frantic braking, it might save you some time!!!
uberNEWB
Bikes: Haro V2 [rip / stolen], PEUGEOT '93 SELECT
front mostly in modulation to slow me down / stop me. rear if its necessary to corner fast or to fistail...at that point im thinking of just getting a coaster brake with a front brake
getting used to modulating the front brake was a lil tricky at first but after about a day of doing it I quickly unlearned back breaking to switch for front breaking.
Tiocfáidh ár Lá
I use the rear brake which is the left hand lever to slow down while approaching barriers or to skid the rear tire out around tight corners. It also helps a bit to slow down but as others said it's mostly the front brake that slows you down.
