New cables won't shift.
Mitcholo
Bikes: 2010 Mitcholo w/ Sram Force/Red
I just installed Nokon cables on my otherwise stock Shimano Ultegra system. Since I installed the cables, the bike won't whift. I've been messing around with the cable tension on the rear derailleur and no matter now much I mess around with it, the shifters won't control the RD. I haven't even gotten to the FD yet, but it's the same.
I've got no stand and no time to do anything drastic. I really don't want to have to take it into work, but I've got a race tomorrow morning and work nonstop from 1pm to 11pm today at two places.
Mooninite
Bikes: $53 Walmart Special
Do you have time to take everything off and re-do it?
I'm not familiar with Nokon, but do they make their housing brake or derailleur specific?
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
Custom User Title
Bikes: 2006 Marin Stelvio, 1990s Steve Bauer, Marin Palisades Trail
I believe that nokon uses slghtly narrower cables than the standard ones, if you used standard cables, that might explain the inability to shift, but then again, if you were able to get the cable through, there should be at least some movement within the housing system.
good luck with it.
good luck with it.
Sounds like maybe you didn't pull the cable tight from the very beginning, or it slipped in the pinch bolt, or possibly the housing is shifting underneath your bar tape if you've retaped already. Start from scratch and be sure to pull the cable taught and tighten securely while in the small cog (no tension) shift position.
Double check inside the shifter to make sure the cable is seated correctly after tightening the RD pinch bolt before you start shifting and adjusting.
Quoted: 114 Post(s)
Liked 119 Times
Originally Posted by ivegotabike
Does the cable move through the housing and not do anything? Or are you unable to move the shift levers?
Can you move the levers?
Are the cables taught?
Is the cable pinch bolt tight?
Are your levers sychronized with the der position?
Bikes: Montague Folding/E-Bike, Kuwahara
Quoted: 31 Post(s)
Something else to check is the cable ends: Is it a clean cut or is it sort of pinched off? If it's pinched off, you'll have to carefully trim off the pinched housing and make it a clean cut.
Quoted: 443 Post(s)
Liked 27 Times
I'm guessing that not everyone knows what Nokon cables are.
https://www.nokon.com/NokonUSA_Products%20(black).htm
