Problems adjusting threadless headset - Cane Creek S6
Dropped
I've had a Cane Creek S6 (with sealed cartridge bearings) installed on a Nashbar touring frame, and I'm having trouble figuring out the proper preload setting.
How in the world is it properly adjusted? I've read parktool and some threads here. Even with the cap and bolt completely removed, and stem bolts loose, I can't feel any knocking, either by hand or by rocking the bike with the front brake applied. I don't have a torque wrench with low enough settings (read in a thread that 12 - 15 in/lbs is the proper torque). I attempted tightening it to find the point where the steerer would have friction, but I ended up pulling the star nut to the top of the tube. I tapped that back down...need it be replaced?
With sealed cartridge bearings, perhaps it will never be over compressed? Or maybe the star nut was never properly installed?
And since I never felt knocking, what's the best way to gauge the tightness? By riding it? Unfortunately, I won't have the drivetrain assembled for a while until some replacement parts come in.
I thought threadless headsets were easier to adjust than threaded!
If you're having star nut issues then I would start there. It should not pull up the tube. Get another one installed by the LBS if you don't have the tool. Star nuts are cheap.
Dropped
Quoted: 2026 Post(s)
Liked 1,096 Times
Originally Posted by JunkYardBike
Actually, I bought the frame and fork used, and the starnut was installed, so I have a spare that came with the headset. Bad idea to tap it down myself? I know centering it properly may be a challenge...
Installing a new star nut without the "proper" tool is rather easy if you are careful.
Thread a long bolt fully into the new nut and center it visually over the steerer tube. Tap it in with a light hammer on the bolt head, keeping it visually straight as you go, until the both flanges are just in the steerer but still too high.
Then I like to remove the bolt, add the top cap and rethread the bolt through the top cap into the nut. That way the top cap acts as a centering guide as you drive the nut down the proper distance - usually 15 mm below the steerer or top spacer top.
I'd preload the headset by hand. A torque of 12-15 inch-pounds is only a little beyond finger tight so you shouldn't have trouble if you just estimate it. You can induce some initial play by loosening the top cap and stem and pulling some slack in the stem's position just to demonstrate to yourself it can be there.
Dropped
Well, after tapping on the star nut for about 30 minutes, wondering how I could jam it in there evenly, I went with vpiuva's advice and brought it to the LBS. Good advice - got it installed and the headset adjusted in 5 minutes.
For what it's worth, it looks like the previous owner of the frameset had installed the starnut himself. The lower "star" was severely bent in one direction, which may have accounted for it loosening. Or it could have been my gorilla tactics with the long handled wrench.
Liked 1,096 Times
Dropped
Originally Posted by HillRider
You may have been "tapping" a bit too gently. Star nuts take some real convincing to start them in. You do want to support the fork well so you don't damage it. Either straddle the fork over a well padded support block or put an old hub in the dropouts to protect them and the fork legs and stand it on the hub.
Bikes: 88 Fisher Gemini tandem, 92 Trek 970, 07 Nashbar Frame, 08 Gary Fisher Paragon
I've done many installs of starnuts with the correct tools and once you understand the forces applied to get these things to work, things like using the bolt and the cap as a guide works very well.
My new fork for my commute bike needed the starnut installed and I used the exact method that Hillrider stated. I used a 2 lb Plastic mallet to start it off and that always seems to work best for me. I should have just waited and used the right tool at the shop, but I wanted to get that fork mounted so bad....
Dropped
