Adjusting hub: Axle compression w/ a solid axle ??
Old 06-27-07, 03:22 PM
Elitist Troglodyte
DMF's Avatar
Bikes: 03 Raleigh Professional (steel)
Shuffling the spacers so a 7-speed freewheel fits the spacing of my tank. I'm adjusting the solid-axle rear hub repeatedly, and I don't understand what I'm seeing.
Using a Stein hub axle vise; adjusting the non-drive side, meaning the drive side is bolted to the vise. What we're looking for is the point where any play in the bearings just disappears. Back off a few degrees and the play would reappear. The wheel should spin freely at that point.
Various techniques produce the same weird result. All start with the locknut backed off:
  • wiggling the rim to feel for play, turn down the cone to just the right point. Hold the cone there and tighten the locknut. The bearings immediately become too tight!
  • adjust the cone until there's a small amount of play - purposely too loose. Tighten the locknut and the play disappears!
  • spin the wheel and take the cone down until drag appears; back off a little. Tighten the locknut and the wheel slows right down.
  • repeat all the above with the wheel bolted to the outside of the dropout (so vertical instead of horizontal) and the same thing happens.
This doesn't make any sense. It's acting like a QR axle, with the axle 'compressing' when the skewer is clamped. But unlike a QR axle, there's no compression applied across the bearings.
What the heck is going on, and how does one find the "sweet spot" without repeated trial and error?
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
DMF is offline
Old 06-27-07, 03:53 PM
Call me The Breeze
I_bRAD's Avatar
Bikes: 2004 Litespeed Siena, 1996 Litespeed Obed, 1992 Miele (unknown model), 1982 Meile Uno LS.
Liked 7 Times in 4 Posts
Is the lock nut tight on the drive side?
I_bRAD is offline
Old 06-27-07, 04:04 PM
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
Quoted: 486 Post(s)
Liked 11 Times in 11 Posts
There is a small amount of play in the threads themselves between the male and female parts, so that the locknut would indeed push the cone down slightly when tightened. This is different than axle compression and is perfectly normal. The usual procedure for adjusting a solid axle bearing is to move the cone down till no play, back off slightly and then tighten the locknut. The difference is that once you have adjusted a solid axle bearing the adjustment does not change when you mount the wheel. For a trained, experienced mechanic it's still trial and error, just less of it.
cny-bikeman is offline
Old 06-27-07, 04:11 PM
Elitist Troglodyte
DMF's Avatar
Yep. And I'm watching the axle to be sure it isn't turning with the adjusting locknut.
- Will Rogers
DMF is offline
Old 06-27-07, 04:15 PM
Elitist Troglodyte
DMF's Avatar
Yes, and the cone wrench doesn't hold the cone perfectly, so I expect some variance. Maybe I'm just not expecting enough.
The usual procedure for adjusting a solid axle bearing is to move the cone down till no play, back off slightly and then tighten the locknut. .
When I do this I end up with a bearing that's too tight - the wheel doesn't spin freely. I suppose this could be compensated by backing off a lot more that one might expect - maybe the full quarter turn that the Park site describes as "purposely too loose".
Which is essentially what I did last iteration and I now have a decently adjusted hub. But I have to go back into it because the drive side spacer is too thin, and I wanted to ask before the (hopefully) last iteration.
- Will Rogers
DMF is offline
Old 06-27-07, 05:42 PM
Mechanic/Tourist
Quoted: 486 Post(s)
Yes, probably so. It all depends on the sloppiness of the thread.
Old 06-27-07, 07:46 PM
Elitist Troglodyte
DMF's Avatar
No "last iteration". I held the drive-side cone still while adding spacer and it came out as good as it went it.
I still don't feel good about it, but the bike is a POS. I'll get more anal if I see something like this on a nice group.
- Will Rogers
DMF is offline
Old 06-28-07, 04:51 AM
Non Tribuo Anus Rodentum and off to the next adventure (RIP)
Stacey's Avatar
The way I deal with this is to adjust the cone a bit loose, holding the cone with a wrench I tighten up the locknut just shy of final torque value. If the bearings tighten up I just back out the cone a bit aganist the locknut until I have proper bearing preload. YMMV
Stacey is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
