Can I apply dry lube over White Lightning?
Blue Light Special
Bikes: '05 Felt F55, Schwinn Prologue road bike, '86 Centurion DS Iron Man, Sette Flite AM MTB
I've been running White Lightning on my chains down here in humid Texas. It's been doing the job fine without making a black greasy mess of things like wet lubes tend to do. Thing is, I'm planning a ride this weekend and the forecast is rain, so I'd like to put some dry teflon lube over the chain. Can I do this without deep cleaning or degreasing the chain to get the White Lightning off? It's been about 100 miles since the last application so maybe it's worn off a bit, but are there any issues with mixing the two types of lubes?
Also, I'm just using the dry lube because I have some left. I'm not sure if a wet lube like Prolink would be a better choice for rainy weather...
Blue Light Special
Ok, so I did a long dry-humid-wet ride this weekend with Prolink on the chain. By the end about 150 miles the chain was covered in a thick layer of black crud. I guess my next question would be how to remove the Prolink completely so I can put my trusty White Lightning back on...(never mind, I'm sure a full degreasing will do the trick).
