Odd problem needing a unique solution, please help.
Here is the problem.
I store my bicycles inside, I have no garage. Our house has a weird little atrium that has been closed in and works as a great place to store the bikes. My wife just put in a tile floor in this area (good small size to practice that on) and she did a great job. So far no problem.
Our youngest cat is a long haired white cat that loves laying on the tile, often right under my bicycles. Can you guess the problem?
Thats right she get chain lube marks on her beautiful white fur.
What I would like to find is some sort of chain cover that I can slip on the bikes just for storage. Nothing permanently attached to the bikes, just something that is simple to put on and take off as needed.
any ideas?
any ideas?
I'm guessing shaving the cat isn't an option
If you have a sewing machine, I'd suggest taking a long oval of scrap fabric and running elastic around the edge - sort of like a long skinny shower cap that you can then pop over the drivetrain.
See You Down The Road
Plastic garbage bag,tear it if you need to,the chain lube will hold it in place till next ride.....use the same one or leave a bag of them close by and wrap,cover,the drive train after each outing.....
Or Shave The Cat
Or Shave The Cat
Chairman of the Bored
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
Dye your cat black...problem solved
Videre non videri
Bikes: 1 road bike (simple, light), 1 TT bike (could be more aero, could be lighter), 1 all-weather commuter and winter bike, 1 Monark 828E ergometer indoor bike
Or make some sort of low "fence" that you seal off the bikes with, preventing the little furry thing from getting near all that grime.
POWERCRANK addict
just throw the cat in the machine with a double scoop of bleach once a week - problem solved
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
Bikes: Trek 2120, LeMond Zurich
Go to Home Depot or Lowes and buy a small length of foam pipe insulation, cut it to the length of the bottom exposed part of your chain and just slip it on when you store your bike. (The insulation is split length wise so it should be easy to install.)
Every day a winding road
Connect the bikes to the 220V line. No problems with the cat and you needn't worry about having your bikes stolen.
Conquer Cancer rider
Bikes: Fun bike, city bike, Bike Friday, Brompton (also fun bikes)
Quoted: 18 Post(s)
This thread is useless without pictures of white cat with black bicycle tattoo.
Although it's also one of the funniest ones I've read for ages.
Zero gallons to the mile
Originally Posted by Blue Order
cut a length of garden hose to the length of your exposed chain, slice it down one side, you now have a sleeve you can slip on and off as needed.
Lanky Lass
Easiest is to flip the bike upside down. Second easiest is to have a sewn cover for the chain, as suggested by Buglady. Cheap, easy, and washable.
We do need photos of the tile job, and the cat. Please.
East Hill
East Hill
___________________________________________________
TRY EMPATHY & HAVE LOVE IN YOUR HEART, PERHAPS I'LL SEE YOU ON THE ROAD...
"Per Ardua ad Surly"
Bikes: Bianchi Specialissima, Mongoose Hilltopper ATB, Surly Cross-Check, Norco City Glide
tired
Bikes: Breezer Uptown 8, U frame
"Real wars of words are harder to win. They require thought, insight, precision, articulation, knowledge, and experience. They require the humility to admit when you are wrong. They recognize that the dialectic is not about making us look at you, but about us all looking together for the truth."
