PowerTap, "Recording Control": HR or Speed?
semifreddo amartuerer
Bikes: several
Which do you use, and why?
Why do I ask? I had been using Heart Rate as the recording control for a long time. I can't remember why. Thinking I might have some influence over HR-related data dropouts, I switched to Speed the other day. My habit is to grab the PT data with PowerAgent and "Merge" all of the individual 'ride-ettes' that show up in the list, then use the resulting data to upload into TrainingPeaks.
I guess it's obvious but it seems like there is quite a difference in the TrainingPeaks analysis (CP #s, probably MMP as well) when you have Speed instead of HR for recording control, especially on a ride with a lot of stops (traffic signals and such). I don't think my fitness improved that much, but a recent ride showed everything longer than CP30 *way* higher than I was expecting based on my PE of the ride. Even some shorter CPs seemed higher than I thought they should be.
What are others' experiences with this? Have I screwed up? Should I go back to HR?
I use speed......can't say why except every computer I have ever had used to speed to start recording. If I had it set to heart rate it would record my 1 hour rest at Starbucks. How embarrassing would that be....
BMC Roadmachine
Kona Jake the Snake
BMC Roadmachine
Kona Jake the Snake
部門ニ/自転車オタク
Bikes: 2008 Blue T16, 2009 Blue RC8, 2012 Blue Norcross CX, 2016 Blue Axino SL, 2016 Scott Scale, Fixie, Fetish Cycles Road Bike (on the trainer)
Speed. Stops less than 5 minutes still factor into your normalized power calculated in cyclingpeaks, so the gaps in recording are counted as zero's anyway.
Envision, Energize, Enable
