Gear Equivalency on Triple Chainring 24 Speed?
Old 07-11-07 | 06:33 AM
Hi guys,
I know that lots of things depend on gear ratios, etc., so I'm looking for a very general answer here:
What gear, on a triple chainring 24 speed, would be ROUGHLY equivalent to a "typical" fixed gear/S.S. gear?
I'm trying to get a sense of how hard you have to pedal on a fixie/S.S. I'm looking for an answer like "approximately the second chain ring up front, and the third smallest chain ring in the back".
Does my question make any sense?
Thanks!
dydst is offline
Reply
Old 07-11-07 | 06:46 AM
rm -rf's Avatar
don't try this at home.
20 Anniversary
I have an easy road gear: 45 -18. That's 45 teeth on the front, 18 on the back. This is about 18mph at 90rpm. A typical fixed gear often comes with a 48 - 16. It's faster on the flats, harder to climb the hills, and is about 21mph at 90rpm.
45 / 18 = 2.5
48 / 16 = 3.0
So count the teeth on your bike. The cogs in the back will usually have the number of teeth stamped on them. Pick a pair, and do the division to get the ratio. So a 39 / 16 is 2.43 and 39 / 15 is 2.6 which are similar to a 45 -18 for instance.
These ratios are usually converted into "gear inches" I'll let someone else explain what it means. The 45 -18 is 66 gear inches, and the 48-16 is 79 gear inches.
rm -rf is offline
Reply
Old 07-11-07 | 06:53 AM
Originally Posted by dydst
Hi guys,
Thanks!
no you can gear your ss bike however you want. If you want 42/14 get 42/14.
Using your 42t middle ring up front people generally people seem to run gears that would be equivalent to 42/14-42/17 or between the 3rd and 6th cog on a 12-26.
dutret is offline
Reply
Old 07-11-07 | 06:58 AM
Aeroplane's Avatar
jack of one or two trades
Bikes: Old-ass gearie hardtail MTB, fix-converted Centurion LeMans commuter, SS hardtail monster MTB
Count the teeth on your big ring. Around 50? Find a cog on the back that is around 18. Try the cogs above and below it as well.
Aeroplane is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
