Spoke vs. Nipple threading...
Commuter
Bikes: Jamis Coda Comp, Kona Killuaea
which is more likely to strip? I have a chronic loose spoke that will not stay tight. I believe both spoke and nipple are stainless steel.
Thanks.
Thanks.
Quoted: 2026 Post(s)
Liked 1,096 Times
The nipple is either chrome plated brass or Al so it would strip before the spoke. I've never heard of stainless steel nipples
Liked 7 Times
Believe I'd replace the nipple and/or locktight the threads, unless there is reason to suspect a bad spoke.
Al
Al
Recreational Commuter
Bikes: One brand-less build-up, and a Connondale Synapse Carbon Ultegra Disc. A nicer bike than I need, but it was a good deal, so... ;-)
Quoted: 7 Post(s)
Liked 5 Times
Before you tigten it again, take a close look at the rim where the nipple emerges and the hub where the spoke sits. You could be getting cracking in one or the other (the rim is more likely).
